shifter peg
Old Jun 13, 2008 | 02:02 PM
Dbl B's Avatar
Dbl B
6th Gear
Default shifter peg
The wife has a 07 lowrider.
She wants to start replacing foot pegs. OK great!
L/R done.
Shifter peg?
How do you get the peg off with out cutting the rubber or destroying the peg?
Old Jun 13, 2008 | 02:08 PM
doncorleone's Avatar
doncorleone
Default RE: shifter peg
I don't think you can. I had to cut mine off my 07 LR to find out that it would take vise grips to unscrew the shaft that the rubber is glued to. If I would have used the vise grips to remove the shifter before removing the rubber, it would have torn up the rubber any way.
Old Jun 13, 2008 | 02:24 PM
expy's Avatar
expy
I used pliers. Got a good grip around it and it came right off.
Old Jun 13, 2008 | 02:26 PM
Dbl B's Avatar
Dbl B
6th Gear
I was afraid of that.
I thought I might save it for&nbsp\\;a spare.
&nbsp\\;
Thanks.
Old Jun 13, 2008 | 02:29 PM
expy's Avatar
expy
Actually I just put the stock pegs back on along with the shifter peg and it still looks new. Thats some tough rubber.
Old Jun 13, 2008 | 02:30 PM
Sammi's Avatar
Sammi
ORIGINAL: expy
&nbsp\\;
&nbsp\\;
+1.
Sammi
Old Jun 13, 2008 | 02:32 PM
expy's Avatar
expy
It unscrews like a normal bolt.
Old Jun 13, 2008 | 02:48 PM
8541hog's Avatar
8541hog
Did you look at the bottom side, mine has a small screw holding it in place. But then I have forward controls.
Old Jun 13, 2008 | 03:01 PM
dyna07custom's Avatar
dyna07custom
ORIGINAL: Sammi
ORIGINAL: expy
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
+1.
Sammi
+2 used small vice grips did not hurt a thing
Old Jun 13, 2008 | 03:22 PM
Don51's Avatar
Don51
How ironic!!!! I have mid controls on an 07 FXDC and mine just fell off by itself when I was pulling into the gas station. I loctite it back on.
