longer shifter lever?
Away from my computer for 5 days...will try to re-post pix when I get home.
Donno why some pix attachments do this.
Again, "prototype". Used to determine upshift and downshift peg placements, but it is functional.
[IMG]local://upfiles/55300/900A63E228E04602BF14514A0B95AE2C.jpg[/IMG]
Pix too big to put in one post...
[IMG]local://upfiles/55300/FF0F611FDF8A4E2F8B215B0DBE40991C.jpg[/IMG]
Will ditch the holy slice of 4x4 alum.angle for shiny chrome steel, eventually.
[IMG]local://upfiles/55300/D3EA5FE011254CC884C51C64C2EDB6BD.jpg[/IMG]
Maybe that's "holey"...
[IMG]local://upfiles/55300/EBAB3685EF584CA99759A5BD36C7BB1A.jpg[/IMG]
I had the same problem after instaling the Kury fat pegs and stirrups. I took off the bolt that holds the shift peg on and moved it up to another setting on the spline and it works fine. It was a VERY easy fix but dont forget to replace the anti seize on the bolt.....
one setting and my boots fit under lever perfectly (for up-shift), but I have to remove foot from peg to down shift. \\; One adjustment down and it is perfect for down-shift (i.e. no need to remove foot from peg), but can't comfortably get boot under shifter (can be done, but not comfortable and can get a little stick (not stuck, just a little snag) when removing). \\; The lower setting works fine with some foot-wear (Timberland hiking boots), but not with the HD boots (non-steel toe) which have a little higher toe-box. \\; I am not interested in a heel toe shifter, but thought that maybe a shifter that was a little longer (from shaft to shifter pad/peg) would do the trick. \\; Does anyone know of one that would fit my Fat Bob that would be longer than stock? \\; Thanks.
the one you're asking about is called the further forward mids kit for dyna's and they did it as a stock option on the 2014 to 17 Low Rider and Low Rider s models. I have installed this further forward mids kit on my Dinah as well but they come with aluminum levers which suck, the splines have already worn out and I can't find any other longer ones without buying a kit.
Bat's last activity was: 08-10-2010 07:54 PM
