rear brake fluid reisvoir on a street bob
Old 07-02-2008, 03:04 PM
freebyrd's Avatar
freebyrd
freebyrd is offline
Default rear brake fluid reisvoir on a street bob
what a pain in the butt to get too, anybody got any tips or tricks for getting the cover off and check the fluid level?
Old 07-02-2008, 03:14 PM
BluBob's Avatar
BluBob
BluBob is offline
Default RE: rear brake fluid reisvoir on a street bob
Pull the battery box cover and you get a little straighter angle on the screws.&nbsp\\; Use a good screwdriver of the correct size, and take care not to strip them.&nbsp\\; Unscrew both screws until they are loose of the resevoir, but still through the cover.&nbsp\\; Reach through from the bottom and take the cover off.&nbsp\\; I use a long funnel with a couple of bends in it.&nbsp\\; A short funnel with a clean, clear hose would work well also.&nbsp\\; Try no to contaiminate the fluid, to include introducing water from the funnel, and remember that that fluid will marr or even remove some paints.&nbsp\\; Look at the gasket when you take the cover off.&nbsp\\; It sticks into the resevoir, and will displace some fluid, so you don't need to fill it to the brim.&nbsp\\; Good luck.
Old 07-02-2008, 06:59 PM
freebyrd's Avatar
freebyrd
freebyrd is offline
yuo i know its a 1/4 inch from the top
freebyrd
scott6610
2014-2023 Touring Models
05-01-2017 03:43 PM
MNPGRider
10-23-2015 04:39 AM
notimeleft
08-26-2013 12:38 PM
doxbike
Wheels/Tires
05-24-2010 09:52 PM
Quick Reply: rear brake fluid reisvoir on a street bob
