code 31 on a wide glide.
Old Jul 5, 2008 | 11:57 AM
The Dude's Avatar
The Dude
Default code 31 on a wide glide.
&nbsp\\;I just&nbsp\\;noticed my lights flashing 6 times indicating a code. This is on a 2001 wide glide. I ran the code test found in the tech section and have a code&nbsp\\;31. I cannot get it to clear. I&nbsp\\; tried to clear it by running the test and holding the left signal down 4 seconds&nbsp\\;and I get the conformation blinks , but before I can turn the ignition back off the code is back.&nbsp\\;From what I read in the tech section its a low voltage to alarm siren??? I don't have a alarm system on this bike. Everything seems to work,signals, etc.&nbsp\\;I pulled all the fuses and cleaned the connections. I disconnected the battery for a 1/2 hour and tried to erase the code that way but no luck. Any ideas?
Old Jul 5, 2008 | 01:38 PM
The Dude's Avatar
The Dude
Default RE: code 31 on a wide glide.
&nbsp\\;Looks like it may be a bad tsm.&nbsp\\;&nbsp\\;Does this have to be married to the bike when replaced&nbsp\\;since it doesn't have security? Does anyone know if this may shut down the bike until I can pick up a replacement? I disconnected the tsm and checked the wire&nbsp\\;#11 going from the tsm plug&nbsp\\;&nbsp\\;to the connector for the optional siren and found no short on #11. The connection for the tsm and plug all look good and clean.&nbsp\\;I am assuming the tsm is faulty.
Old Jul 8, 2008 | 05:59 PM
The Dude's Avatar
The Dude
&nbsp\\;I fixed it. Mods can go ahead and delete this thread if need be.
Quay
General Topics/Tech Tips
Mar 17, 2025 10:27 AM
hdfxdwg2001
Nov 29, 2013 06:52 AM
spoolit
Sep 17, 2010 08:31 PM
ponesma
Dec 2, 2008 10:20 AM
roadrunner68
Apr 12, 2007 07:31 AM
