FXDC Wheels
Old Jul 9, 2008 | 04:39 PM
brillopat883's Avatar
brillopat883
Default FXDC Wheels
Greetings, just wanted some non-biased non-dealer straight answers.&nbsp\\; Will the pre-bullet hole solid Fat Boy rims (Circa 2004-2006) fit on a '08 Custom?&nbsp\\; Is there anything special I need to do to the bike to put a set on if they do fit?&nbsp\\; Thanks&nbsp\\;
&nbsp\\;
......Remember, Jet Noise is the sound of Freedom!
Old Jul 10, 2008 | 03:24 AM
jmpancoast's Avatar
jmpancoast
Default RE: FXDC Wheels
I believe you are going to run into axle size issues, bearing size issues, and hub width issues.&nbsp\\;
&nbsp\\;
The 08s have a 25mm axle.&nbsp\\; You will have to change the bearings in older wheels you want to install.
&nbsp\\;
I believe a couple other guys have posted wanting to do the Fat Boy wheels on the mid-glide Dynas and found the hubs were too wide for the&nbsp\\;space&nbsp\\;in the tubes.&nbsp\\; I think one actually had some mill work done to his sliders to get them to work.&nbsp\\;
&nbsp\\;
Maybe you can dig this info up doing a search.
&nbsp\\;
Good luck.
&nbsp\\;
John
northgate
Jul 29, 2008 05:13 PM
Paul.C.
Jul 12, 2008 06:23 PM
cwilli
Jul 9, 2008 04:25 AM
oldgeezer
Jun 12, 2008 06:30 AM
BLLYGOAT
Jun 7, 2008 03:09 PM
