front headlight
Old Jul 29, 2008 | 10:33 AM
GORLOPP's Avatar
GORLOPP
Default front headlight
I have '04 lowrider and want to put a longer billet headlight&nbsp\\; on it. But I have not found anyone that makes one that will have the bolt mounted on the bottom&nbsp\\; instead of top. mine goes through the top for the headlight cover. Don't really want to get rid of cover because of the warning lights. Anyone have any ideas?&nbsp\\;
Old Jul 29, 2008 | 11:16 AM
2007fxdc's Avatar
2007fxdc
Default RE: front headlight
You could get rid of the idiot lights and drill the bottom tree.
Old Jul 29, 2008 | 11:55 AM
GORLOPP's Avatar
GORLOPP
Yeah I think I'm going to have to.
Old Jul 29, 2008 | 12:15 PM
2007fxdc's Avatar
2007fxdc
I've asked around before for my buddy that has an 03 lowrider and that was the solution most suggested.
Old Jul 29, 2008 | 12:21 PM
GORLOPP's Avatar
GORLOPP
Thanks for the info. Time to start drilling.
Old Jul 29, 2008 | 12:26 PM
glide05's Avatar
glide05
as mentioned - save your time looking.
there is no alternate top mount solution.
Old Jul 29, 2008 | 09:17 PM
Streets of Fire's Avatar
Streets of Fire
Is there a good alternative for the idiot lights?
Old Jul 30, 2008 | 12:10 AM
GarretG's Avatar
GarretG
Hey now,
I had the stock eyebrow headlight and transformed it to a billet lamp assembly.&nbsp\\;\\\\\\; Using the existing modified light assembly I got the attached results.&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
What I did was remove the indicator light assembly, then the eyebrow/light assembly.&nbsp\\;\\\\\\; I then used a small band saw to cut off the brow along the molding lines on the back of it.&nbsp\\;\\\\\\; I then took a half round file to make the curves for the risers.&nbsp\\;\\\\\\; Did a little finish filing, polishing, and reinstalled the bracket backwards with the same hardware.&nbsp\\;\\\\\\; I then reinstalled the indicator light assm. (in reverse of course)&nbsp\\;\\\\\\; &nbsp\\;\\\\\\;
I then installed the new billet light assembly I ordered from the HD catalog.&nbsp\\;\\\\\\; This required drilling a 3/8" hole in the lower triple tree.&nbsp\\;\\\\\\; I used a front motor mount bolt thru to the lamp mounting bracket.&nbsp\\;\\\\\\; I spliced the wires and hid the connections under the gauge cluster.&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
Thats it,&nbsp\\;\\\\\\;good luck contact me for questions of more photos.&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
Peace,
Garret
Thumbnail Image
Thumbnail Image
Thumbnail Image
&nbsp\\;
Old Jul 30, 2008 | 12:44 AM
rayfinseats's Avatar
rayfinseats
Try a thick trim ring. It makes a big difference. Way easier mod.
Old Jul 30, 2008 | 06:52 AM
FastHarley's Avatar
FastHarley
Former Sponsor
ORIGINAL: GarretG
Hey now,
I had the stock eyebrow headlight and transformed it to a billet lamp assembly.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; Using the existing modified light assembly I got the attached results.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;&nbsp\\;\\\\ \\;\\\\\\\\\\\\\\;
What I did was remove the indicator light assembly, then the eyebrow/light assembly.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; I then used a small band saw to cut off the brow along the molding lines on the back of it.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; I then took a half round file to make the curves for the risers.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; Did a little finish filing, polishing, and reinstalled the bracket backwards with the same hardware.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; I then reinstalled the indicator light assm. (in reverse of course)&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; &nbsp\\;\\\\\\;\\\\\\\\\\\\\\;
I then installed the new billet light assembly I ordered from the HD catalog.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; This required drilling a 3/8" hole in the lower triple tree.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; I used a front motor mount bolt thru to the lamp mounting bracket.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; I spliced the wires and hid the connections under the gauge cluster.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;&nbsp\\;\\\\ \\;\\\\\\\\\\\\\\;
Thats it,&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;good luck contact me for questions of more photos.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;&nbsp\\;\\\\\ \;\\\\\\\\\\\\\\;
Peace,
Garret
Thumbnail Image
Thumbnail Image
Thumbnail Image
&nbsp\\;\\\\\\;
Very good solution IMO Looks good!!!!
