Front end wobble on decel......any suggestions?
Old 07-17-2012, 08:13 PM
gartec81's Avatar
gartec81
gartec81 is offline
neck bearing adjustment. fall away
Old 07-18-2012, 08:41 AM
Reaper_ggy's Avatar
Reaper_ggy
Reaper_ggy is offline
Originally Posted by dyna rider
You need to follow the instructions that PowerCobra98 put out...Have someone sit on the bike to keep it level or use a wheel chock. Jack the engine till the bolts are free turning (after the torque has been broken). When they are free turning, that is when you measure the gap. You don't have to take the bolts all the way out...you just need to make sure the mount is unloaded so it is not supporting the engine.
This may or may not cure your problem...as said before, fall away, tires, front and rear tire alignment, rear motor mount, etc.
Ok ... thanks i'll double check that , the bolts are on the floor. Maybe the fact that I removed rear shocks didnt help, might doing too much thing at the same time.
Old 07-18-2012, 09:01 AM
Reaper_ggy's Avatar
Reaper_ggy
As for the torque on the bolt they were so easy to take off I wonder If they were tight enough in the first place ...(never touched them before) And my vibration occure the most in 6th speed, its sluggish tried many speeds but until I beat the bike it wont stops vibrating
Old 07-19-2012, 06:48 PM
Reaper_ggy's Avatar
Reaper_ggy
Same thing, I asked someone to take the bike straight ... jacked the motor and it can reach the frame. If I let the bolts on they restrain the motor to go up by the lenght of the bolts so ... Cant figure out the good way to know the amount of the shims needed
Old 07-19-2012, 08:35 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Front Mount
Did you put the shocks back on the bike ? I would think they need to be on the bike to check the mounts. What are you jacking the motor with ? If the rocker boxes are hitting the frame then you are going WAAAYYYYY TO FAR. Put the bolts back in the front mount,do not tighten, and jack the motor till the bolts turn freely. Walmart and Northern Tool both sell scissors jacks for 20 bucks or less and come in real handy for this. If you are using a floor jack on it, your lifting way to much.
You can also go to the under $50.00 thread and search for the 4x10 wooden jack and use it instead of having a person hold the bike upright but you will still need a scissors jack for the motor.
It's little movements that do this whole thing.
to fast to live
08-06-2015 03:54 PM
Born2Glide
10-21-2010 03:37 PM
amish
08-29-2009 02:17 AM
Stanger
04-11-2009 10:31 AM
mastergenie
08-15-2008 12:56 PM
Quick Reply: Front end wobble on decel......any suggestions?
