Big radius install
Old Aug 21, 2008 | 07:32 PM
roofer's Avatar
roofer
Default Big radius install
Is it easier to install the pipes with the heat shields on or off Thanks
Old Aug 21, 2008 | 09:43 PM
DOORZ's Avatar
DOORZ
I did mine with the heat shields off. Can't say for sure if it's easier, but it was no big deal to install them after. I would rather do it after so less risk in damaging a heat shield during install.
Old Aug 21, 2008 | 11:28 PM
rounder's Avatar
rounder
I installed pipes then installed shields after... quick easy and painless...
Old Aug 22, 2008 | 01:29 AM
OhioSkully's Avatar
OhioSkully
You won't be able to get to one of the bolts on the rear cylinder with the heat shields on.
Old Aug 22, 2008 | 10:01 AM
JRK5892's Avatar
JRK5892
do not forget the exhaust gaskets!
Old Aug 22, 2008 | 10:58 AM
drtheo's Avatar
drtheo
better w/out the shields especially when getting those pesky header bolts threaded. After the shields go on pretty easily
Old Oct 2, 2008 | 09:09 PM
tgenerous40's Avatar
tgenerous40
Stage I
I have 700 miles on my bike and will be installing a set of Big Radius Pipes this weekend.......would it be okay to use the original exhaust gaskets??? Thanks
Old Oct 2, 2008 | 09:55 PM
Slipstrm's Avatar
Slipstrm
Get new exhaust seals they are only about $4 a piece.
Old Oct 3, 2008 | 11:35 AM
EDZ82FXR's Avatar
EDZ82FXR
Just put vance and hines big radius on my Street Bob yesterday!!! I talked to JRK about alot of things he is very informative and I appreciated his help...Install the heat shields after you have the pipes on the bike, the rear and front cyclinder bolts are kind of a pain with the heat shields on *on my stock pipes* and all this is comming from what JRK said to me. Def get some anti sieze and some exhaust gaskets they are def not reusible...Take your time and line them up and make sure everything is tightened down after everything is lined up of course. I have the link for directions if you didnt get these new http://www.vanceandhines.com/download/D515IN.pdf GOOD LUCK And I know you wont be dissapointed
Old Oct 3, 2008 | 01:55 PM
r00k's Avatar
r00k
Just use new gaskets, they are cheap and easy to replace.
Just like some of my ex-girlfriends.
