Primary fluid
Old Aug 29, 2008 | 09:25 PM
Frankster69's Avatar
Frankster69
Default Primary fluid
I'm leaving on a trip in the morning and I'm a little low on primary fluid , I'm running syn 3 in it now. Would it hurt any thing if I topped it off with reg HD primary oil? Thanks
Old Aug 29, 2008 | 09:35 PM
mustasz's Avatar
mustasz
You can fill primary with almost anything,I use 10W40 motorcycle oil,as long as your primary has enough oil it's OK.You can mix synthetic with regular,doesn't make a difference.,In primary you just oil the chain.
Old Aug 29, 2008 | 09:38 PM
mud's Avatar
mud
and the clutch
mud
Old Aug 29, 2008 | 09:42 PM
maddghost's Avatar
maddghost
How do you get low on primary oil? I guess is you have a leak sawwy.
Frankster69
My inner primary seal leaks a little I have to get it fixed. Does'nt leak much so I'm not fixing it till winter. Thanks I did'nt want to wait for HD to open.
dennyo
Feb 23, 2015 08:06 PM
jphillips
Sep 3, 2014 10:03 AM
hogblue
Oil Archive (no new posts)
Mar 8, 2010 04:12 PM
tencrore
May 24, 2009 02:32 PM
jepps
13
Jun 28, 2008 09:25 AM
