Clutch adjust
Old Sep 19, 2008 | 01:58 PM
JRK5892's Avatar
JRK5892
man just adjust it... takes no time... loosen the cable till it has all the slack in it (cable by the down tube), take off the derby cover, break the stay bolt loose... back off the set screw screw it in till it seats, back off a 1/4 turn tighten that sucker down with the set bolt... take the play out of the cable at the down tube cable adjustment so that there is enough play in the lever to fit a nickel in there... if you are worried about it... adjust it... takes no time
Old Oct 6, 2008 | 05:07 PM
Foley Fats's Avatar
Foley Fats
Is that jam nut behind the derby cover a reverse thread? Mine seems to be too tight to break loose.
Old Oct 6, 2008 | 05:23 PM
BluBob's Avatar
BluBob
It's standard thread on mine. You should be able to see the threads if you are not sure. Don't let the bike roll off the jiffy stand if you are cranking on it........
Old Oct 6, 2008 | 05:37 PM
Foley Fats's Avatar
Foley Fats
The dealer must have tightened it up too tight the last time. It looks like regular thread to me. Reckon it is safe to use an impact wrench on it? Thanks for the help.
Old Oct 6, 2008 | 06:11 PM
Foley Fats's Avatar
Foley Fats
I got it. Just had to get a longer handle wrench. thanks for the help.
Old Oct 6, 2008 | 07:33 PM
06dynablack's Avatar
06dynablack
next time if you cant turn it loose.just give the wrench a good blow generally all it takes to break it loose/if that dont work you can put bike i gear and have another hold the rear brake while you loosen the nut. yeah theres no need to trque that nut.I just give the wremch a good hit with hand once its seated.
Old Oct 6, 2008 | 07:55 PM
Sec Super Glide's Avatar
Sec Super Glide
Glad to see some things never change!.
Old Oct 6, 2008 | 08:16 PM
06dynablack
??? meaning what? Or did you read the whole thread knowing what the outcome of this was gona be.yeah it might be repeats of same questions answers here but I would just as soon as give a answer again instead of telling them there is a search button for it
cjones55555
General Topics/Tech Tips
11
Jan 23, 2018 06:29 PM
cjbmustang
Sep 4, 2012 09:34 PM
Kebo
Jun 7, 2012 03:16 PM
Dew Me
May 11, 2012 10:02 PM
JARK
Dec 15, 2008 08:24 AM
