sudden free play in clutch cable
Old May 7, 2017 | 08:03 PM
cjones55555's Avatar
cjones55555
Default sudden free play in clutch cable
My clutch lever suddenly went slack and the lever stayed against the handlebars. Had to have the bike trailered home. Thought it was a broken clutch cable so I replaced it. No change. (The old cable still looked ok) So I removed the primary and pulled the clutch pack. Everything looks fine. Still have a ton of slack in the cable though. There's not enough adjustment to take up all the slack. It happened suddenly so when I took everything apart I really thought I'd see something broke. Nope, everything looked seems perfect.
I have the shop manual but not sure what to look for anymore.
Any ideas?
Old May 7, 2017 | 08:58 PM
Road Gliderman's Avatar
Road Gliderman
When you took the primary apart what did the clutch spring look like? that is the only thing pulling your clutch cable.
Old May 8, 2017 | 10:53 AM
Uncle Fuzzy's Avatar
Uncle Fuzzy
Ball and ramp?
Old May 8, 2017 | 11:59 AM
nevil's Avatar
nevil
I'm also thinking you need to check the ramp and see if the ***** are all in there. Hopefully it's that simple.
Old May 8, 2017 | 03:36 PM
Max Headflow's Avatar
Max Headflow
If the center adjuster in the clutch pressure plate is still in place and the clutch not falling off the shaft, the throwout bearing probably disintegrated..
Old May 9, 2017 | 08:58 PM
cjones55555
ramp and ball looked perfect. There really are no springs on my clutch pack. There's a spring like plate that seemed to be in good shape. The throw out bearing is on the ball and ramp side, right? hmmm. I didn't look at that. Damn. Looks like I'm draining the transmission again.
Old May 9, 2017 | 09:04 PM
Uncle Fuzzy
Clutch spring should look something like this
Old May 10, 2017 | 06:31 PM
cjones55555
That's what mine looks like. It seems springy. It looks like it's in good shape. Do you think it should look damaged since the clutch lever to the bar happened so suddenly?
Old May 10, 2017 | 06:57 PM
Uncle Fuzzy
I would think so..
Check your throw out bearing.
Is your motor stock?
What year are we talking about?
Old May 12, 2017 | 07:22 AM
cjones55555
Bought a new throwout bearing. Haven't gone back in to the clutch cover side yet. That bearing is so small. I don't see how that would allow the lever to suddenly go to get completely slack and rest on the handlebar but... ****, definitely worth replacing. It was only a couple bucks. Thanks for the direction on what to do. I'll update the thread as soon as I get it fixed.
