Tail light install
Old Oct 19, 2008 | 12:38 PM
SC-Longhair's Avatar
SC-Longhair
Default Tail light install
Yes, I have the service manual. (This seems a good starting line to most threads, to cut out the extraneous "buy a service manual" posts).
I bought this light for my wg:
It has turn signals built into it. It is not LED. Standard bulbs. There are no instruction with this light but seems pretty cut and dry but the wiring seems to be a bit confusing. It has 1 wire for left ts, 1 wire for right ts, 1 power for the taillight and one ground. That's 4 wires altogether.
Looking at the service manual before oem taillight disassembly, there are a bunch of extra wires. It seems each connection has it's own dedicated ground. I'm no master electrician and wanted to know if I can twist all ground wires together to make one common connection?
Also, since the new taillight only has one power lead, is this going to cause a problem with operation? Regarding stock harness, does the taillight and brake light run through the same lead?
From the service manual, it shows a circuit board in the back of the oem taillight assembly, is this just a connection point or is there circuitry in there that I need to be concerned with?
I suspect after I swap out for the new light, I'll have some extra wires to deal with. I don't want to cause a short, and/or end up with a serious electrical problem.
I'm not an idiot but definitely want to make sure I understand what needs to be done before I start tearing into it.
Old Oct 19, 2008 | 01:34 PM
mud's Avatar
mud
Yeah all the grounds can be common.
There is a wiring diagram here
https://www.hdforums.com/forum/showt...78#post2616578
Old Oct 19, 2008 | 09:41 PM
Baeseman1's Avatar
Baeseman1
I just tore into it... lol My light didn't come with any instructions, but the manual helped a lot. I cut my harness off and soldered the new tail light wires to the existing. Eliminated the left/right directional harness and just used the main harness wires. Not much room under the fender, so take your time. My light isn't much different than yours...
Old Oct 19, 2008 | 09:48 PM
SC-Longhair
You know I was eyeing that tail light also. I was a little concerned with the leds and brightness. How do you like it? Also, I don't want to destroy the harness if at all possible. I'm still paying for my bike.
Old Oct 20, 2008 | 07:19 AM
Mascman's Avatar
Mascman
Is that going to work as a tail AND brake light?
If you don't have a dual-filament bulb then it will have to be one or the other, right?
Is it possible that the fourth wire is not a ground, but for brake or tail and that the light is ground by the mounting bolts?
Old Oct 20, 2008 | 01:07 PM
SC-Longhair
Well, there wasn't any info in the packaging BUT it was listed in jpcycles as a "taillight/turn signal combo". Since the entire casing is metal, I suppose it's possible that it could be the ground. I haven't opened it up to see what's inside yet.
Old Oct 20, 2008 | 01:57 PM
rdondes's Avatar
rdondes
JP Cycles is always saying they have 24 hour phone support for anything they sell. Why don't you call them? Maybe they are familiar with the light and its installation. Here is their technical support contact information/phone numbers:
Technical Support Harley-Davidson& & Vintage:
Toll: 1-800-397-4844
International: 1-319-462-4816
Metric & Sportbike:
Toll: 1-800-318-6847
International: 1-319-462-3699
Hours:
Monday-Friday: 7am - 8pm CST
Saturday: 8am - 5pm CST
Sunday: We're out riding our bikes!
Richard...
Old Oct 20, 2008 | 02:59 PM
SC-Longhair
I had thought about that earlier. Kinda surprised they couldn't even stick a little wiring diagram on a napkin in the package.
Old Oct 20, 2008 | 04:06 PM
formike56's Avatar
formike56
brake lights & turn signals operate with the same wire. the wires should be Ground, L turn, R turn, running light. Good luck
Old Oct 20, 2008 | 04:08 PM
Mascman's Avatar
Mascman
If you can get to the middle bulb, check for the dual filament.
If it's a single then you'll have to decide wether to run it as a tail or brake light.
Could possibly wire in a new socket with a dual filament.
