Hardware List
Old Nov 10, 2008 | 10:47 AM
Low_Wider's Avatar
Low_Wider
Default Hardware List
One of my winter projects will be to start swapping out a lot of the stock hardware for chrome parts. Wishful thinking maybe but does anyone know of a list that gives the sizes of the various nuts/bolts used? If it makes a difference I'm running an '06 TC88, thanks.
Old Nov 10, 2008 | 10:54 AM
dyna rider's Avatar
dyna rider
Wink Hardware List
Try logging on to www.customchrome.com They have what you need in kits or remove and take to Ace Hardware as they have the best selection of chrome hardware locally. Another option is to buy a parts manual for your bike as it has every fastener listed by part number and you can look them all up by part number which will give you size and thread pitch.
Old Nov 10, 2008 | 12:07 PM
JRK5892's Avatar
JRK5892
man i use a hot topper kit on my ride... LOVE IT!!! got all black, looks so clean... i have used the chrome as well... hold up great to the heat and looks tops!
hope that was your ?
Old Nov 10, 2008 | 12:20 PM
Low_Wider's Avatar
Low_Wider
Joe,
I had thought about Hot Toppers but was concerned that they would not look as good as the "real" thing. It is certainly less money and effort than replacing the entire bolt. I'll definitely look in that direction as well, thanks.
Old Nov 10, 2008 | 01:11 PM
Grind's Avatar
Grind
Just a note about Hot Toppers, that someone else posted a while ago. If you don't do your own wrenchin', dealer or indy will probably charge you hourly rate to take them off. Plus, he might not be too careful, breaking them; and probably won't put them back on for you, handing you a baggie of them instead. Again , this is something to think about, only if you pay someone to do you fixin' and servicin'.
Don't get me wrong, I think HTs are pretty cool, and will probably put them on my bike when I get it.
Old Nov 10, 2008 | 01:27 PM
JRK5892's Avatar
JRK5892
they pop right on and off... the chrome looks tops! here is a pic of the sporty in all chrome as well as my bob with the black (before i got them all on)
here are some pics to give you an idea of how they look
every bolt hot topper chrome (you can not even see them on the side cases of the motor) sorry no close ups that i have... i can ask my brother... the bike has since been sold
black:
Old Nov 10, 2008 | 03:55 PM
rounder's Avatar
rounder
after you tighten each bolt, clear the inside of em. Save rust headaches later on.
1986gbody
Jun 26, 2019 05:45 PM
04FXDI
Apr 9, 2018 02:41 PM
crzoomb
May 23, 2016 05:10 AM
shortride
Jun 24, 2009 02:36 PM
OneBlackFly
Sep 23, 2007 12:43 PM
