Custom running lights??
Old Nov 14, 2008 | 11:27 AM
BlockHead96's Avatar
BlockHead96
Default Custom running lights??
Something for more visibility from the rear. Low profile, lean etc.. Anybody got ideas or links???
I've seen some nice ones that slip over the end of the fender struts for a clean smooth look, but have no idea where to find this type.
Old Nov 14, 2008 | 11:59 AM
8541hog's Avatar
8541hog
Somehow more visibility and lean, low profile don't go together. Only option sounds like a small LED type light. Lots of those available.
The ones I have seen that fit the struts don't seem to have DOT approval, least not the ones I have seen so far. I looked for wuite a while before I found some smaller bullet types for my WG, these are the ones I bought for mine.
http://cgi.ebay.com/ebaymotors/HARLE...3A1|240%3A1318
Old Nov 14, 2008 | 01:18 PM
dyna rider's Avatar
dyna rider
Default Rear Lights
The turn signals that fit the struts are from : www.alloyart.com Why is it a problem if they are not DOT ?
Old Nov 14, 2008 | 01:22 PM
8541hog's Avatar
8541hog
It could be an issue if you live in a state that has mandatory vehicle inspections every year or so, like VA does. Not that i agree with it, just pointing it out for reference is all.
Old Nov 14, 2008 | 04:40 PM
BlockHead96
Being they are LED, how will that effect the electrical system??? I've already had issues with engine shut down using the turn signal/brake light/running light mod. I believe it interferes with the security system. Isn't there something else the light has to be connected to?
Old Nov 14, 2008 | 06:21 PM
8541hog's Avatar
8541hog
I have never run LED's, you may need a load balancer, guess I am old school, I want lamps I can get at any auto parts store.
Old Nov 14, 2008 | 06:25 PM
rockon's Avatar
rockon
I ordered a set of LEDs for my ride about a week ago, along with a load equalizer...I'll be posting about it once the install is done.
Old Nov 14, 2008 | 07:17 PM
dyna rider's Avatar
dyna rider
Default Leds
Blockhead96-I read your thoughts (in another post) about the Harley load equalizer and your bike shutting down. I can understand your frustration with the problem. I have run a Harley equalizer for about 2 years now without a problem. I have had the bike shut down on me before but that was due to another electrical problem that I caused. I have a set of led turn signal bulbs in the rear signals now and have had them there for about a year now without incident.
Old Nov 15, 2008 | 01:05 AM
BlockHead96
I don't know if you need an equalizer for the LED's so long as you're not using them as turn signals.
Does your bike have the security system??
Old Nov 15, 2008 | 01:07 AM
BlockHead96
Are you getting the Alloy Art's?? If so, let us know if they come with mounting hardware as I'm real curious as to how the wires are run thru- the strut and fender..
