front end swap
Old Dec 26, 2008 | 04:41 PM
krazhik's Avatar
krazhik
Question front end swap
Anyone know how difficult it would be to swap a stock springer front end from a softail? I know alot would depend on what bike it came from and what year but would the hieght be a problem? Can you lower a springer front end to match a dyna? Would 3 degree raked tree's work with a springer? Should this swap just be totally forgotten becuase it wont work? I just saw a few adds and got to thinking about a stock springer swap as opposed to a fatboy or heritage front end swap.
Old Dec 26, 2008 | 08:51 PM
dpriest's Avatar
dpriest
maybe do a search on this forum. i'm sure someone here has done it. good luck.
Old Dec 26, 2008 | 09:27 PM
Sumpnut's Avatar
Sumpnut
Smile
Have seen it done somewhere..looks good
Old Dec 27, 2008 | 02:21 AM
WS6 Formula's Avatar
WS6 Formula
https://www.hdforums.com/forum/dyna-...inger-bob.html
Old Dec 27, 2008 | 07:55 AM
08fxdf43202's Avatar
08fxdf43202
IMO there's just something about a springer front end on a swing arm frame that just doesn't seem right.
Old Dec 27, 2008 | 10:07 AM
speedjunkie's Avatar
speedjunkie
Do a search under member id's. Gorilla, Kpreese, and Kansashellride have all got springers under their dynas. To me, and this is only me, the external shocks of a dyna kind of distract from the springer front end. Not to mention, the bike needs to be the right color too. A dark color seems to bring out the springer, whether in black or chrome.
I had considered a springer conversion too, but with my bike, I just can't quite see it, so it's going to be a WG conversion instead! Best of luck!
Mike
Old Dec 27, 2008 | 10:18 AM
pococj's Avatar
pococj
By now you've probably seen the other thread, but I'll toss in a couple thoughts related to things I noticed in your post.
You can't lower a springer without changing (cutting/welding) the front and rear legs, except by installing a set of custom rockers that move the position of the front axle relative to the rest of the front end. This can dramatically affect trail, which can cause handling problems if not engineered correctly.
Springer trees are completely different from hydraulic tube trees, so there is no direct changing. The springer top tree is removable, while the bottom tree is normally welded to the rear legs. Also, the top spring perch is welded to the rear legs. That makes a lot of work to change the rake. Some spring forks have a built-in rake; I don't know about the stock HD version. I have seen custom springers with raked trees, and well-designed rockers to achieve correct trail.
Old Dec 27, 2008 | 03:26 PM
krazhik's Avatar
krazhik
Thanks for the reply's. After considering what pococj posted and looking at a few bikes i dont think what i want would work / work well. Thanks everyone for clearing things up though and you guys here with springers i think your bikes look great, just not what i was going for.
BlessedHellride
Aug 28, 2014 05:43 PM
smketr7139
Nov 30, 2010 08:42 PM
oldnewby
Feb 4, 2010 07:57 PM
Twincam Dave
Jan 12, 2008 01:54 PM
toyrider
Apr 9, 2007 01:33 AM
