power outlet question
Old Jan 4, 2009 | 10:52 AM
imcworth's Avatar
imcworth
I have decided to hard wire the outlet. I'm installing it under my seat facing out on the left side for easy plug in access. then i am looping the charger up under the seat to the tank
protector where my iphone which has a ipod will be. Then I will be able to use my new Toy. These bad boys are completely wireless. with headphones built right in and bluetooth I can listen to tunes and answer the phone while cruising around. I will post pictures when i am done. Anyone who wishes they had tunes while riding these are the S**t. No Wires make it comfortable the headphones on this unit also hold your glasses on tight.
Old Jan 4, 2009 | 11:40 AM
amish's Avatar
amish
imcworth lets see some pics when your done. also how do you like that new toy?good sound?how does it pick up a signal from you ipod?
thanks for the info
Old Jan 4, 2009 | 11:48 AM
imcworth's Avatar
imcworth
well first off there are two models of those Glasses 1 pair has a MP3 player built in so you would download your music like an ipod. $199.00.. The pair I bought is a bluetooth so i can talk on the phone and listen to tunes wireless. $249.00 plus you need to by a little unit $49.00 to listen to the music wireless and it has a port on the bottom to charge the phone while your listening to it. which is why i need an power outlet. Also the sound is top quality.
[URL=http://g.imageshack.us/img293/77698614042qi5.jpg/1/][IMG]
Old Jan 4, 2009 | 11:59 AM
pennetta's Avatar
pennetta
Harley sell a connector that plugs directly into an open connector on the stock wire harness under the seat. Its the open grey connector. This gives you three total open hot leads, the original plus two new ones. I have my license plate light hooked into this because I did not want to cut any wires. The only problem is that this line is always hot, even with the key turned to off. I have a separate swith at my license plate to turn it off/on.
Old Jan 4, 2009 | 12:10 PM
imcworth's Avatar
imcworth
Can't run a direct 12volt power into the Iphone needs to go through a car charger. I also need the outlet to be waterproof for bike washing and getting caught in the rain. Harley does'nt sell a waterproof power outlet. so i went to Kragen auto parts and found a concealled power unit that connects directly to the battery protected by a fuse 7.5 amp . I will post pictures when done.
Old Jan 4, 2009 | 01:07 PM
jwlehman's Avatar
jwlehman
Those Oakleys are cool...but man, $350.00 and sit on them once or lose them...it would be enuff to make ya cry
Old Jan 4, 2009 | 05:34 PM
obonaven's Avatar
obonaven
Have a part number for that bad boy?
EJP777
Jan 21, 2018 05:54 AM
Neil_Gros
May 6, 2009 08:02 PM
bosken
Jul 15, 2008 02:06 PM
wydopn231
Mar 2, 2008 02:29 PM
