left grip removal
Old Jan 31, 2009 | 08:56 AM
txtec's Avatar
txtec
Question left grip removal
anybody know a trick to removing the left glued on grip without destroying it??? i"am putting my stock bars back on and dont want to by another 50 dollar set of grips.can they be reused??? also what would a set of mini apes with all throttle cables,clutch cable,front brake line of a 06 st bob be worth???
Old Jan 31, 2009 | 09:07 AM
Solitaree1's Avatar
Solitaree1
everyone has tried different things from heatguns to solvents. I'm unaware of any of them working.
Old Jan 31, 2009 | 09:09 AM
HOGRIDA_06's Avatar
HOGRIDA_06
To get the grip off...Try heat, twist and pull. I sold my stock Bob bars and cables to a friend of a friend for $50. If he was a close friend I would have given them to him.
Old Jan 31, 2009 | 09:10 AM
Lorance66's Avatar
Lorance66
I was able to get mine off by squirting a small bit of WD40 under as much of the grip as I could lift up and then blowing compressed air under it, then just twist a bit and presto.....off
Old Jan 31, 2009 | 09:33 AM
sniper77's Avatar
sniper77
I took my ISOs off with a patient twist, and a bit of PB blaster.
It came off without damage and to re-install it after getting the slippery stuff off, I used the grip glue (about $4) from the dealer.
Old Jan 31, 2009 | 09:41 AM
Dave54's Avatar
Dave54
long skinny screwdriver but go slowly and twist a lot more twisting than prying
Old Jan 31, 2009 | 09:43 AM
Grind's Avatar
Grind
I've heard of the compressed air method being the most successful.
Would you take $50?
Old Jan 31, 2009 | 10:14 AM
txtec's Avatar
txtec
thanks for the quick answers,wd40 and air worked pretty good,cant take 50,the stainless braid brake line alone cost me 80 bucks
Old Jan 31, 2009 | 11:13 AM
sniper77's Avatar
sniper77
You didn't give people enough information. You said St.Bob apes and cables and lines, you failed to mention you had aftermarket braided lines. Do you have the cables to match also?
If you have braided stainless cables and brake line with a set of stock mini apes you should be able to get at least $125 -$175 for the cables and brake line and throw in the bars for free to get rid of them.
Old Jan 31, 2009 | 02:48 PM
wmo777's Avatar
wmo777
Sniper,
What is PB Blaster?
