Kury Fuel Gauge
Kury Fuel Gauge
I tried to do a search and didn't find an answer to this question. I installed the Kury fuel gauge in my SB, but noticed that the low fuel light on the spedo doesn't come on... I cut the yellow/white wire coming from the connector on the back of the spedo and then soldered the gray wire to it (the end that comes out of the connector), left the other end lose, put it all back together, calibrated the gauge so now the red light is blinking [empty] but no light on the spedo. Did I do something wrong or is the spedo fuel light disabled now? I thought that when the fuel was low it would register on the Kury and the spedo
Any input appreciated.
Believe me when you see the red led start flashing it gets your attention right away. Much easier to see and IMHO is better than the stock setup.
Yeah, it is hard to miss that flashing red light. I had the tank down to just about "E" on the old gauge when I calibrated it... will have to see where that really is (forgot to check how much gas I put in the tank, but I know it can't be much).
It is a LOT easier to read then the old gauge that's for sure.
jmpancoast
01-17-2008 03:57 AM
