Need Help!!!
Old Feb 28, 2009 | 09:40 PM
Frog33's Avatar
Frog33
Default Need Help!!!
I put on some Boss Blades awhile back and now I am having some trouble with the clutch engaging. I thought the new lever was just not coming back far enough. So I put my old lever back on and same problem. I can pull in the clutch and bike is still in gear. Can this be fixed adjusting the pack, or a problem with the cable in the tranny? Hope this makes sense...
Old Feb 28, 2009 | 09:43 PM
archergodwin's Avatar
archergodwin
Sounds like time for a clutch pack adjustment and clutch cable adjustment. Do you have a service manual?
Old Feb 28, 2009 | 09:47 PM
Frog33's Avatar
Frog33
Going to get one tomorrow, I have been putting it off, but now it seems it has come back to bite me. I know how to adjust the cable, the pack on the other hand is a little foriegn to me.
Old Feb 28, 2009 | 09:54 PM
tlb's Avatar
tlb
what year and model bike do you have?
Old Feb 28, 2009 | 10:18 PM
bakerm75's Avatar
bakerm75
Heres a couple of links that might help.
forum instructions
youtube video
Oh and make sure you tighten and release the allen a couple of times to take the slack out of the cable. you should feel the clutch lever extend and release when you turn it in different directions. Get the handle where you want it and squeeze and release the clutch to make sure the clutch moves in and out before sealing it up.
After I did mine I could not push it while in 1st gear. I could start it, and ride fine.
after a good hours ride it loosened up and I'm able to push it.
I understand this happens when the clutch pads get stuck together.
Old Mar 1, 2009 | 12:17 AM
AAA88's Avatar
AAA88
release the jam nut from the adjustment nut on the cable adjuster and then adjust the clutch pak until you are where you want to be and then after that adjust your clutch cable.
Old Mar 1, 2009 | 06:52 PM
Frog33's Avatar
Frog33
Thanks for all the input. Going to start the fix tomorrow, can I do this on the kickstand, or is this something I really need a jack for???
Subduedracer
Jul 31, 2013 10:38 PM
taygull
Apr 3, 2013 01:48 PM
Night train David
Jul 17, 2011 06:26 PM
neverdown
Jun 29, 2009 07:56 PM
