05 Dyna Speedometer
Old Mar 20, 2009 | 01:14 PM
mcdaniel52761's Avatar
mcdaniel52761
Default 05 Dyna Speedometer
ok.....I've read the forums and checked out the 09 GMA catalog, but still can't nail down exactly what I need part number wise. I'm looking to take the speedometer from my 05 FXD and instead of it being above the handlebars, putting it below. Since I purchased the bike used, I'm assuming that the handlebars are stock. Is this a relatively easy job to do? Thanks for your help and direction,
Mike
Old Mar 20, 2009 | 01:43 PM
rounder's Avatar
rounder
Can you post a picture of your bike? you could buy a sportster custom riser setup and do it that way. Probably going to want to switch the bars. If you go to a t-bar or tall risers and drags, you can get a mount that will fit (last saint has one on his bike now). you will have to relocate the idiot lights or remove them completely.
Old Mar 20, 2009 | 03:02 PM
bberck's Avatar
bberck
Ya a picture of what you have would help us.
The stock set-up for your 05 is basically the same as my 08 was. It had a little different style clamp but looks relatively the same. So if it doesnt look similiar then its not the stock set-up.
Pic (sorry best I had)
If the bike has taller risers or T-Bars you can go with a Accutronic mount. A forum member just also had a mount made that looks real good that moved the speedo underneath. I will see if I can find the thread.
EDIT: Here is the mount he had made.
https://www.hdforums.com/forum/dyna-...prototype.html
I went with the 07 FXDSE set-up on mine. Its kinda pricey but got new bars, speedo mount and tach.
Old Mar 20, 2009 | 03:04 PM
greenyetti's Avatar
greenyetti
I too am looking to make similar change on my '03 FXD let me know what you find out
Old Mar 20, 2009 | 04:32 PM
mcdaniel52761
Sorry....didn't think about the pics. I ran out and snapped a couple. So, am I to assume that you have to get new bars as well to make this work? I would think there should be some kind of mount that you can take what you have and give it a 180 turn, shorten it up so it doesn't hit the tank and there ya go. Probably wishful thinking.
Attached Thumbnails 05 Dyna Speedometer-dsc_0202.jpg   05 Dyna Speedometer-dsc_0203.jpg   05 Dyna Speedometer-dsc_0204.jpg
Old Mar 20, 2009 | 07:06 PM
bberck's Avatar
bberck
Ya most options will require you to use new bars.
You can get a riser speedo mount from a Sportster Custom and use it. You could then still use your current bars and should be able to get by with the stock cables.
Old Mar 21, 2009 | 01:08 AM
greenyetti's Avatar
greenyetti
bbreck....
Hey man, do you have a part # for those '07 fxdse bars?? I looked all over HD parts and couldn't find em. Thanx
Old Mar 21, 2009 | 12:31 PM
bberck's Avatar
bberck
Originally Posted by greenyetti
bbreck....
PM sent
Old Mar 21, 2009 | 12:51 PM
Mr. Moto's Avatar
Mr. Moto
You can get the following from a 00-03 Sportster. This set up will turn your speedo 180 on the tank side.
Top clamp 56074-96
Speedo Bracket 67084-96
Check this thread out from the Sportster section.
https://www.hdforums.com/forum/sport...p-concept.html
Old Jan 29, 2010 | 07:06 AM
pepper8892's Avatar
pepper8892
Hi,
Where can I buy a speedo mount like this??? I have been looking Hi and Low for one, thank you if you can let me know...
