Tool Kits
Old Mar 25, 2009 | 11:49 AM
ssls6's Avatar
ssls6
Zip ties, a Phillips screwdriver, allen wrench for the seat, & multitool.
I think it's important to be able to remove the seat and battery cover. Zip ties to hold stuff together and a multitool so you have a knife and pliers.
Old Mar 25, 2009 | 12:11 PM
hprather's Avatar
hprather
6th Gear
You all are great! Some helpful ideas about what gear to carry and how to carry the gear in these posts.
Thanks to each of you---Hugh
Old Mar 25, 2009 | 12:36 PM
shimmon's Avatar
shimmon
I made up a tool kit to carry on longer rides and trips... Havent had to use it since i've made it this winter and the riding season just started but i got a cheap fork/tool bag and plan on mounting it on the front lower frame rails or on the left rear swingarm... A few wrenches, multi tool, e-tape, zip ties, allen, torx, and screw driver
Old Mar 25, 2009 | 01:29 PM
frankjake's Avatar
frankjake
Originally Posted by JaronB
Here's the tool roll I got! I haven't had to use it yet, but it comes with everything you need. The flashlight in it is a POS and swapped it out with a mini mag, but it fits perfect in a tool bag. It's windzone tool roll and put in a standard harley fork bag and mounted it to the bottom of the frame!
http://cgi.ebay.com/ebaymotors/Windz...Q5fAccessories
Looks like a good little kit for the money. Half the price of the Cruz tools and looks like twice as many tools. And seems to fit nicely in the tool bag. I think I'll order one but add a Co2 tire repair kit.
So far the only thing I've had to use on any of my bikes was some type of wrench to tighten a loose bolt or battery cable. And the Co2 tire filler.
Old Mar 25, 2009 | 03:55 PM
roadkillvespa's Avatar
roadkillvespa
I have a bit of a thing about toolkits and like to carry enough tools to be able to do pretty much everything I need to on the bike.
Sooo...I carry a set of AF combination ring/open end spanners,an AF folding allen set,a full set of torx bits,2 philips bits,2 slot bits and bit driver,mulititool,few 3/8 sockets,3/8 ratchet,C spanner,19mm 1/2 socket for front spindle nut,28mm 1/2 socket for back spindle,3/8 to 1/2 converter with T bar hole and 2 1/2 extensions to make long T bar so I can actually undo the spindle nuts!,as many spare nuts and bolts and zip ties as I can cram in,weighs a ton!
I usually carry a small punture repair outfit in my jacket pocket and if I going on a trip and have the bags on I'll take a spare innertube too,19 in can be used front or rear in an emergency and a hand pump.
I carry everything in this
Seems overkill but if you had every tried to call a breakdown service in some parts of Scotland you'd know why.
Old Mar 25, 2009 | 04:13 PM
00ICUR12's Avatar
00ICUR12
One thing I haven't seen mentioned, and I always carry, is a spare taillight and headlight bulb.
Old Mar 25, 2009 | 09:44 PM
evesweater's Avatar
evesweater
Roadkillvespa,
I like the canister. I was actually holding up my maglite flashlight up to the bike today in the same spot thinking that style would look cool, if I could find the tubing and match it on both sides.
Old Mar 25, 2009 | 10:14 PM
JaronB's Avatar
JaronB
Yea I removed a couple pieces that I wouldn't need. It came with two different size spark plug sockets, so got rid of the one I didn't need. Came with an extra bulb and took it out. I'll pack it when I go on long rides. It may be a tight squeeze for the CO2 tire patch kit, but I have an 11" bag. You might be able to make it work. If you got the 12" fork bag it should work great. My fork bag was $24 at Harley so it's worth a shot, you can always return it.
Old Mar 26, 2009 | 04:03 AM
roadkillvespa
Originally Posted by evesweater
Roadkillvespa,
The canister is actually an operators manual holder for a tractor !
I have two and tried one on each side but the right hand one was just a bit close to the exhaust.
My canisters came from the USA and are available from a company called Agrisupply for $4.99.
http://www.agrisupply.com/manual-can...900088/c2c/sc/
Roger Williams
Aug 16, 2013 02:41 AM
jd8181
Apr 9, 2013 08:23 AM
tcabello
Dec 24, 2011 06:44 AM
3skulls
Aug 2, 2010 04:57 AM
Durkdigler13
Nov 8, 2009 10:35 AM
