need help bad
Old Mar 28, 2009 | 04:18 PM
wideglide46928's Avatar
wideglide46928
Exclamation need help bad
ok end of last summer my wg battery was bad got one at walmart last a monthwas dead and all acid was gone from battery.got another from walmart lasted 2 weeks samething .ok now i got a harley battery lasted a few days was dead.now i checked the stator getting 16-18 at 1000 rpm 2000 rpm getting double that.so i got a new voltage regulator.rode about a mile square.then let it run for about half hour.still dead.is that enough to charge it.should i charge with my charger first.i am getting very p@@@@@ at it.help
Old Mar 28, 2009 | 05:03 PM
jmpancoast's Avatar
jmpancoast
You need to slowly charge your battery with a trickle type charger (battery tender). Bring it up slow and maintain it with the tendor. The bike's charging system does OK keeping a battery charged, but ain't good for charging a battery.
Old Mar 28, 2009 | 05:27 PM
soonerfan's Avatar
soonerfan
Default Battery
Had same problem with my HD battery. had to replace my battery. got a battery tender and it fixed the problem.
Old Mar 28, 2009 | 05:42 PM
bakerm75's Avatar
bakerm75
Agreed, you can burn a deep cycle battery ( like the one in your bike, camper or boat) by charging it with out a deep cycle battery charger, or simply jumping it. I believe the max you want to put in at a time would be 10amps.
Sears sells a manual charger that works on your car also for about 30$
But I recommend spending a little more for the Automatic charger that will monitor the battery to see when its full and not burn it.
or a good trickle charger will work.
You may want to verify that your ground cables are in good condition and grounding properly.
hogcity5's Avatar
hogcity5
Did you try a voltage meter at the battery posts? At that point you should be throwing about 14-14.4 volts to the battery if everything is charging properly. Next guess would be the stator starting to short. Hope this helps.
Old Mar 28, 2009 | 05:43 PM
wideglide46928
ok so i need to charge it all the way up harley charging system is only good for kepping it charged.and yes i get 14 or so when running or setting still .i ll try that thanks just dont wanna be stuck somewhere again lol
Old Mar 28, 2009 | 05:46 PM
bakerm75's Avatar
bakerm75
Harleys starters can be picky too. I know that come spring if I don't get a full charge on my battery, I will end up stuck somewhere clicking.
Old Mar 28, 2009 | 05:50 PM
Shovel Die Hard's Avatar
Shovel Die Hard
all bike batteries i've bought are not ready out of the box, and they need a very slow deep charge before use, like everyone already said. 1.5 amps is ideal. battery tenders are great
i do know the dealers around here will charge the battery for you for free if you buy it there, so if you don't have the proper equipment there's an option.
Old Mar 28, 2009 | 06:41 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Hey wideglide I bought a voltmeter with L.E.D.s that at least tell you how many volts are being produced by the charging system. It's from Kuryakyn and available thru most aftermarket vendors. I've got mine mounted to the front master cylinder. Harleys run off the batteries juice and the charging systems only job is charge the battery, not running the electrics. An AGM battery with a battery tender plus is the best way to maintain that battery.
Old Mar 28, 2009 | 08:09 PM
dyna rider's Avatar
dyna rider
Default Charging System
You will have to ride it about 10-20miles to charge the battery back up from starting it. I've noticed that if I don't ride far enough after I start the bike, the battery tender stays on high charge a lot longer than usual. A battery tender is a great idea.
