Vibration
Old Apr 12, 2009 | 08:12 AM
BLACKFLST's Avatar
BLACKFLST
Default Vibration
I just took the first ride of the season. And i have a bad vibration just off idle. Im thinking it might be because it is cold. It was a short ride through town. Maybe when it warms out side it wont be as bad.
Old Apr 12, 2009 | 08:29 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
My bike always rides rough until completely warmed up. Ride it 20 minutes minimum and put some fresh fuel in it.
Old Apr 12, 2009 | 08:46 AM
JohnAE's Avatar
JohnAE
How old is the gas and did you put stabilizer in the fuel when you parked it? As mentioned, putting new gas in it will probably solve the problem. My MC always runs bad after sitting for a few months. I also run a little carb. or fuel injector cleaner through every few tankfuls. I can't say I notice any real difference in performance after adding the cleaner with my motorcycles but really do with my cars. I figure it can't hurt.
Old Apr 12, 2009 | 11:36 AM
the blob's Avatar
the blob
what brand do you use? i may try that my self as ive never used any.
Old Apr 12, 2009 | 12:27 PM
KBFXDLI's Avatar
KBFXDLI
Try 2-3 oz of Chevron Techron with a full tank of fuel.
Old Apr 13, 2009 | 06:43 AM
BLACKFLST's Avatar
BLACKFLST
i took out all the old gas and put new gas in before i started the bike. i think im going to try a spacer on the front motmr mount like i see on other posts.
Old Apr 13, 2009 | 07:49 AM
drhooligan's Avatar
drhooligan
I put (2) washers which totaled about 3/16" in thickness between the front mtr mount and the frame as described in another thread. Very significant reduction in vibration, nearly none at all when cruising around 3K. Great, simple, modification.
Old Apr 13, 2009 | 09:03 AM
archergodwin's Avatar
archergodwin
I would read a bit more, because folks are getting good results from adjusting ALL the motor mounts. Some have reported adverse handling after shimming.
Old Apr 13, 2009 | 09:15 AM
first dyna 07's Avatar
first dyna 07
Hey Man
I would check the front motor mount it may be going bad ? It's just a thought .
k-hook
Apr 30, 2011 07:19 PM
garrisons54
Nov 6, 2009 11:20 AM
FloridaDrafter
Apr 29, 2008 06:57 PM
sparky_mo
Nov 22, 2007 01:29 PM
joellynn3
Nov 13, 2007 03:50 PM
