FXDL Problems
Old Apr 13, 2009 | 08:19 PM
dbmmorin's Avatar
dbmmorin
Stage II
Default FXDL Problems
New to harleys and I need some help. I bought a bike (2002 fxdl) that can't go around a corner, especially right ones, without scraping the ground and wanting to right itself. It is scraping underneath on a little bracet that is welded to the frame to protect the motor. I have always heard from harley guys how well they can rail turns so I hope some changes can help this bike. After some research, I now realize I should have looked for an FXDX. Experience is not the issue. I am hoping to rectify this problem with 13.5 inch rear shocks. Any advice would be greatly appreciated.
Thanks
Mike
Old Apr 13, 2009 | 08:39 PM
dyna rider's Avatar
dyna rider
Default Shocks and Springs
You need longer shocks for sure. Measure the length of your current shocks from eye center to eye center and go with much longer ones. I personally would try 13" or 13.5". You might also have to change the front fork springs. What ever it takes to raise the bike...
Old Apr 13, 2009 | 09:03 PM
TheBigBear's Avatar
TheBigBear
For that to drag,the whole bike must be really lowered,agree with checking shock length,but you may have other things to check also.Did they have smaller dia. tire on?
Old Apr 13, 2009 | 10:01 PM
20LowRider02's Avatar
20LowRider02
I would think that you would hit the peg or exhaust first, depending on exhaust and if you have forwards or not. It definitely sounds lowered. I've only hit that if I leave a driveway or go over a speed bump a little too fast.
Old Apr 14, 2009 | 08:51 AM
dbmmorin's Avatar
dbmmorin
Stage II
Thanks Guys,
The current shocks are 11.5" eye to eye and the stock tire is still on the bike for now. I will be heading to the harley swap meet in Keene NH in may. I should be able to hook up with some shocks there. My remaining quesation is the front. Do I need spacers, longer springs of stiffer springs? Maybe a combo of the two?
Thanks again
Mike
Old Apr 14, 2009 | 11:56 AM
SC-Longhair's Avatar
SC-Longhair
Why don't you check to see what stock shock height was. I think they're around 12" or so.
Zack1
Apr 21, 2017 02:12 PM
slowrollin
Apr 6, 2014 08:26 PM
nebrown1
Shovelhead
Feb 24, 2012 05:49 PM
itsmf
Mar 17, 2011 08:16 PM
DannyNucclz
Jun 3, 2007 03:20 PM
