Anyone using a fairing?
Old Apr 20, 2009 | 01:44 PM
Marksman's Avatar
Marksman
Originally Posted by AdrianVall
Installing it on the bob?!!?!? well, I guess you can make anything look good.
Man that was my question!
I thought Joe had a bike for every occasion.
I'll withhold judgement till I see it.
greg3131 what are you trying to do?
I ride alot in the cold and put on a quick release Plexi-Faring for the winter. It helps alot, but is butt ugly. I use small sheild in the warmer months.
SURFOR Chop's Avatar
SURFOR Chop
Originally Posted by Black Bart
Why, I don't even use a windshield!
Bart
I'm guessing you don't ride the freeway at 75 MPH for an hour-and-a-half twice a day in 35 - 45 degree weather in the rain ...
Try that for a few months and get back to me ....
R/
Priest
Old Apr 20, 2009 | 01:49 PM
phatman's Avatar
phatman
Originally Posted by Priest
Uh ... yeah ...
But, when I'm ripping ... this is how I roll ...
I actually think that looks pretty good. where did you get that fairing?
Old Apr 20, 2009 | 01:51 PM
JRK5892's Avatar
JRK5892
Pirate boy did his as well.... man Priest, i wish you would have set this up prior to changing the front end! now i have to do complete metal fab!
Old Apr 20, 2009 | 01:55 PM
greg3131's Avatar
greg3131
Priest that looks good, where did you get that?
Marksman, two reasons the stereo and long rides.
Old Apr 20, 2009 | 01:56 PM
Marksman's Avatar
Marksman
Priest and Pirate boy. Are those the same farings?
Preist I'm impressed. That FLST front end is awesome.
Did you do a thread on this conversion?
I love it.
Old Apr 20, 2009 | 02:18 PM
SURFOR Chop
I love it.
Hey all ... not sure if Pirate boy still hangs out in the Dyna forum ... a few months after his conversion he got a Street Glide I seem to recall ....
He posted a thread on how he did his fairing ....
I had a thread on my conversion, but I didn't have too many photos ... I mostly followed a link to an excellent pictoral and gouge on how to do a FLST front end conversion: http://www.kenandjudy.us/Harley%20Pi...tEnd/index.htm
See my comments below from another thread on the subject ....
As you're probably aware I've got a fairing and had looked at several before settling on a Tsukayu ... paid $978 for a gloss black painted outer fairing with no radio. As you may be aware, I now have a FLST front end so the fairing is made to fit.
That is not the case for most fairings out there with the exception of Corbin, K-D VanillaZilla for Sportsters (should fit '05 and earlier Dyna) and SW Audio ... only three that I am aware of.
I had investigated several options, as follow:
- Dragonfly (http://www.dragonflycycleconcepts.com/fairings.htm)
- Dead Center (http://www.deadcentercycles.com/default.aspx)
- K-D (http://www.debrix.com/items/item.aspx?itemid=1280827)
- Kevin Evans (http://store.kevinevans.org/detachablefairing6x9.aspx)
- Hoppe Industries (http://www.hoppeindustries.com/)
- Wide Open (http://www.wideopencustom.com/dotnet...0/Default.aspx)
I used to have a narrow glide with a quick detach (QD) windshield. It occurs to me that one way to apply a fairing to a standard Dyna would take about three easy steps:
1. Obtain one of the fairings above (or one of about another half dozen or so sources) made for Road King and Softail models.
2. Bend the right and left mounting brackets in mirror images at two planes to narrow them to the proper width.
3. Remove the cam-lock clamps from the QD windshield and attach (bolt) the clamps to the mounting points of the fairing.
You would then be able to simply clamp the fairing to your bike using the QD windshield clamps.
A couple of caveats - for FXD, which have the riser mounted speedometer, you'd have to use a fairing with no inner shell (as I have done); the top-to-bottom distance between the clamps may not fall between your triple trees, so the lower clamp may clamp the fork tube below the triple tree. I do not see why that should be a problem.
Another observation - you'll need to move your turn signals from your handlebars so they can still be seen.
Thought I'd pass on some thoughts on the subject ....
R/
Priest
... p.s. another alternative to 2. above might just be to use some spacers ....
Old Apr 20, 2009 | 02:31 PM
78fxs78's Avatar
78fxs78
Just get a full size detachable windsheild, Memphis Shades are decent.
Old Apr 20, 2009 | 02:48 PM
JRK5892's Avatar
JRK5892
i got one... i still like the full protection from the wind on long trips... plus it is cool it is all quick release
Old Apr 20, 2009 | 04:46 PM
SURFOR Chop
I had a full size detachable windshield before ... it just offers no protection for your hands ... when you're riding for two hours in 37 degree weather in a drizzle, your hands can really get uncomfortable ...
If you're not going to be riding in quite such extreme conditions, I tend to agree ... a fairing is a little overkill for your average ride ....
Can sure cut down the fatigue factor, though, when you're going to be touring for long-distance rides ....
R/
Priest
