Quote:
Yes. You have to remove the mounting brackets for the stock FXD exhaust system, then install the mounting bracket for the Fat Bob exhaust system. Once you do that, the Fat Bob headers and mufflers will bolt right on.Originally Posted by JackJ3200
Does anyone know if you can fit the stock exhaust from a fat bob onto a superglide?
+1 here. I think someone in these forums has done it.
Excellent. Thanks much Gary. I love how that exhaust looks but didn't know how much work it would be. When you say the mounting bracket you are referring to the "bar" mounted to the trans and pipes correct?
Quote:
The bar that connects to the muffs doesn't connect to anything else. There is a bracket that bolts to the transmission case that secures the rear header and one that bolts to the engine case that secures the front header. Those have to be removed, and the Fat Bob exhaust bracket can then be installed.Originally Posted by JackJ3200
You need to get a service manual for you bike before you tackle this.
