Primary Problem?
Old May 9, 2006 | 11:20 AM
Omen666's Avatar
Omen666
Default Primary Problem?
I noticed last nite that one of the bolts on my primary is missing. I'm going in for my 1000 mile check up on May 20th. Is this something I should take care of now or can it wait?
Old May 9, 2006 | 11:27 AM
glebo's Avatar
glebo
Default RE: Primary Problem?
Is it leaking?? If not I would just throw a like bolt in the hole so there is one there. However, if one was loose I would assume that others were loose, so I would check the rest of them. [&:] Those bolts may have been put in on a friday!! And miller time was approaching.
Old May 9, 2006 | 11:36 AM
Omen666's Avatar
Omen666
No leaking. Thanks, I'll check them when I get home.
Old May 9, 2006 | 11:52 AM
needadyna's Avatar
needadyna
If it was on the inspection cover, (not the derby cover), there are 2 different sizes.
Old May 9, 2006 | 03:00 PM
phreak's Avatar
phreak
ORIGINAL: needadyna
No inspection cover on an 06.
I would definately make a point of calling the dealer and letting them know the bolt is missing. Get the issue documented as soon as possible so they don't try and come back on you.
Old May 9, 2006 | 04:04 PM
gbm's Avatar
gbm
I'd replace it. All the cap screws on the primary side are 1/4-20 thread. When you stick the new screw in the hole and you've got 1/2" to 5/8" sticking out (not threaded yet) you're close on the correct length. Clutch cover screws need a small washer.
smittyp83
Milwaukee Eight (M8)
28
Apr 22, 2018 06:20 PM
jf7689
EVO
Oct 18, 2016 10:14 PM
Good_Apollo
Jul 4, 2012 08:19 AM
wwglide
Sep 20, 2007 09:05 AM
Beefcake
General Topics/Tech Tips
Jun 21, 2005 09:11 AM
