Throw over bag mod
Old May 8, 2009 | 09:46 PM
Wireguided's Avatar
Wireguided
Default Throw over bag mod
I picked up some bags last year for trips.
But now that ive gone to a solo with and without the passenger pad.
As well as new paint i didnt want the bags on my rear fender paint.
I dont care what you use it still gets beaten up.
So i took my detach back rest apart.
Drilled holes in the side plates.
used two small carriage bolts (from the inside) and a brace inside to keep it from flappin in the wind.
Cut the throw over flaps completely off,drilled 2 holes in each bag and used a 3/8 teflon spacer 1.5 inch by 6.5 x 3/8 thick to keep the bag level with the detach bolts at the lowest point of contact from the sideplate.
Now when i get to where im goin i just pop my quick release and the bags with pack attached to the rack and bar come off in one shot .
Same as a quick release backrest .
Tomorrow ill post some pics in stages as i get ready to finish the job.
I need one more bolt.
Hope this helps someone..
Link to pics
http://good-times.webshots.com/album/571908346kcaxPE
Old May 8, 2009 | 09:52 PM
cdn-bigfoot's Avatar
cdn-bigfoot
Hey WG.
I've been planning on doing exactly that. You gave me the confidence to go ahead and do it.
Hey, do your bags hang over your sidemount plate?
We've gotta ride together once this year.
I'm in St.Albert. You're Calgary right?
Old May 8, 2009 | 10:00 PM
Wireguided's Avatar
Wireguided
Yeah ill be up there in june at the new norway run..june 19.20.21
As well as the ride for sight june 12.13.14. (Olds)
Thanks for the comments.
Ive been meaning to do it since fall but it is easy and cost me 10$ total.
Ill bring you the needed parts when i see you..
As for the side mount i think it will be ok you can still see it.
Old May 8, 2009 | 10:05 PM
cdn-bigfoot
I'll be doing the Edmonton Ride for Sight. I hope to get through Calgary a couple times this season.
I won't need the parts. I'm gonna do that mod this month. Thanks for the offer though.
I might make the New Norway run Sat AM, but I'm going to a good WBA Heavyweight title fight at River Cree on June 20th in the evening.
Old May 9, 2009 | 11:04 PM
Wireguided's Avatar
Wireguided
Well i tried to upload pics to here but it would not let me so here is a link
To pics of this project..
Old May 9, 2009 | 11:14 PM
cpl215's Avatar
cpl215
Did you have any chipping of the chrome on the sideplates when you drilled them?
Old May 9, 2009 | 11:15 PM
Wireguided's Avatar
Wireguided
none at all....
Old May 9, 2009 | 11:24 PM
cpl215's Avatar
cpl215
Good deal that is a great mod, was thinking of getting easy brackets but now I am thinking this may be the way to go.
Old May 9, 2009 | 11:26 PM
BoomerBob's Avatar
BoomerBob
Link to pics
That's a really good idea. I'm surprised I haven't seen it before now 'cause it makes perfect sense. Thanks for sharing the idea and the pics.
Old May 10, 2009 | 05:08 AM
scott_db's Avatar
scott_db
Looks good, thanks for the pics. I was thinking about this too.
