I want to wideglide my 2007 fxd
Old 05-22-2009, 11:42 AM
Chrome Grinder's Avatar
Chrome Grinder
Chrome Grinder is offline
Default I want to wideglide my 2007 fxd
Does any one have the wheel spacer part numbers that will allow me to put a wide front end on my fxd and keep using my stock wheel?
Old 05-22-2009, 11:54 AM
ratt196635's Avatar
ratt196635
ratt196635 is offline
I had to make mine to use different wheels and tried the stock and had to make custom ones for it to. Somewhere there is a post that a guy made a list of everything needed to use a wideglide front end do a search and you should find it or someone will direct you to it.
Old 05-22-2009, 11:57 AM
man4mopar's Avatar
man4mopar
man4mopar is offline
I can't help you with the wheel spacers accept they are not that hard to make.
I am replying to metion that you will likely need to space the brake rotor out to align with the caliper. Also if your looking to reuse your stock fender will need spacers for it too.
Maybe someone that has done what your looking to do will chime in with measured pieces. I doubt there is a part # kit out there, but I could be wrong.
Old 05-22-2009, 12:46 PM
ratt196635's Avatar
ratt196635
I also had to space the rotor out but chose to space the caliper out instead was eaiser and had to make less spacers. You can just get you a wide glide fender to replace yours or space it out. I went a different way with mine and used a fatboy fender since the fatboy has a wide glide style front end
Old 05-22-2009, 01:27 PM
cramil's Avatar
cramil
cramil is offline
search for conversion kits on the web. there are several I have seen that address wheel spacing and rotor spacing but most I think were for the 41mm older set up. Just get a wide glide wheel too.
https://www.hdforums.com/forum/dyna-...er-photos.html
https://www.hdforums.com/forum/dyna-...-on-fxdbi.html
Old 05-22-2009, 03:35 PM
Gwjvw's Avatar
Gwjvw
Gwjvw is offline
SAve lots of money and buy a take off 21in, i think i paid 100 bucks to do my whole wg front end, 21in rim/tire, wg chrom tress, spacers etc! Instead of leaving it a midglide and go have my crap relaced buy new custom spokes and rim and hub and labor etc And i get to sell my 19in complete rim for 250 bucks
Old 05-22-2009, 05:02 PM
2NAHNTR's Avatar
2NAHNTR
2NAHNTR is offline
Check out Motorway engineering (aka Vulcan Engineering ). They have a bunch of spacers and triple tree conversion kits. I converted my front end from a narrow glide to a mid glide with one of their kits.
http://vulcanworks.net/store_4/home.php
Old 05-22-2009, 10:39 PM
bklynbob's Avatar
bklynbob
bklynbob is offline
Default mid- glide......a little difernt
www.customcycleengineering.com
Old 05-22-2009, 11:42 PM
rounder's Avatar
rounder
rounder is offline
Leave it alone you have plenty of width....
junglejoe
EVO
07-20-2014 08:33 AM
erkblack
04-18-2012 09:50 AM
floridian46
11-01-2010 04:46 PM
DR. V-TWIN
01-26-2010 07:40 PM
bigscooter
11-06-2006 03:16 PM
Quick Reply: I want to wideglide my 2007 fxd
