Changing outer primary
Old May 23, 2009 | 08:03 AM
YellowHawk's Avatar
YellowHawk
Default Changing outer primary
I bought a new gasket yesterday and today I'm planning on changing my silver powdercoated outer primary to a new wrinkle black one. Is there anything I should check inside once I get the old primary cover off?
Old May 23, 2009 | 08:43 AM
scooterr68's Avatar
scooterr68
I am thinking of the same thing! love to see some pics.
Old May 23, 2009 | 09:21 AM
Low_Wider's Avatar
Low_Wider
I won't be changing my cover but will have to pull it as I've sprung a leak around the shifter shaft. I was wondering the same thing as you as this will be the first time I've pulled it. I was stunned when the stealer charged me $40 for the cover gasket and $4 for the shaft seal. It'd be nice to know if there are other places you can get gaskets and seals rather than paying through the nose to the stealers.
Old May 23, 2009 | 11:00 AM
06dynablack's Avatar
06dynablack
you can save thru online dealers such as chicago hd
Old May 23, 2009 | 11:21 AM
powdercoater's Avatar
powdercoater
There are lots of online places to buy HD gaskets at discount prices but quality should be the higher priority over price! Low quality gaskets will result in changing them often... THEN how much money will you really be saving?
Old May 23, 2009 | 04:53 PM
SuperFastGlide's Avatar
SuperFastGlide
inspect the chain and tensioner shoe,
Old May 23, 2009 | 07:34 PM
YellowHawk's Avatar
YellowHawk
Got it changed. Everything looked good to me inside the primary.
Low Wider, I thought the same thing when I bought the new gasket yesterday. I think it was like $35.00!!! For a gasket!!! When I took off the primary, my old one looked just as good as the brand new one so I said screw it and reused the old one. I'll keep a check on it for leaks. If it does leak I'll change it. I'm confident it won't. I'll hang on to the gasket for later on.
Old May 23, 2009 | 08:18 PM
SuperFastGlide
ive actually reused the gasket with no probs
Old Sep 30, 2009 | 11:49 PM
JimmieJack's Avatar
JimmieJack
I was planning on changing the primary cover. When replacing the gasket - do you use a gasket sealer like a permatex or just bolt it up plain?
Old Oct 1, 2009 | 12:06 AM
09DynaMan's Avatar
09DynaMan
bolt it up plain
just make sure both mating surfaces are COMPLETELY clean and dry
