slip on's almost slipped off
Old 06-11-2009, 06:02 PM
JoeGrapes's Avatar
JoeGrapes
JoeGrapes is offline
Default slip on's almost slipped off
I read a post on here a few days ago about a guy who had his slip on mufflers fall off. Last week I put a set of Screamin Eagle slip on's on my 07 FXDC and they're just the right sound for me. Anyway, I thought I'd check to see if they were loose. The rear one was good and tight but the front one was loose. What the hell, I said, I made sure they were tight when I put them on. So I got out the socket and sure enough they were both tight. I looked closer at the clamp on the loose muffler and noticed that it was just about an 1/8" over the solid part of the pipe. When I moved the clamp so the slot in the pipe was just starting to show and then tighten it down, bingo the muffler was nice and tight. So if anyone has just put a set of mufflers on go back and check on the clamp to be sure it's not clamping over the solid part of the pipe. It dosen't take much.
Old 06-11-2009, 08:14 PM
thedonthere's Avatar
thedonthere
thedonthere is offline
Put 1 rivet through the clamp, slip on and head pipe. Then you'll never worry about your slip ons becoming slip offs.
Old 06-11-2009, 08:19 PM
maddghost's Avatar
maddghost
maddghost is offline
Everyone on here told me to torque slipons as tight as I could,then ride it around to get it hotone time and tighten them down again. I never had a problem with my slipons!
Old 06-11-2009, 08:22 PM
FATBOB.'s Avatar
FATBOB.
FATBOB. is offline
call your harley dealer , they will tell you the spec to torque
them down.after enjoy your ride...
Old 06-11-2009, 10:13 PM
GeorgeJ's Avatar
GeorgeJ
GeorgeJ is offline
I had the same problem. Fixed it by getting a new set of clamps. They seem to have a "use once then throw away" characteristic as do many HD fasteners. - George
Old 06-11-2009, 10:34 PM
2007z71's Avatar
2007z71
2007z71 is offline
Yep, I know that guy that had his fall off!!! HEHE! I am still buying parts for that dumb ACE mishap. Thanks to several of the guys from this site I am hoping I will be riding by the weekend. Thanks for the tip.
Old 06-11-2009, 10:56 PM
rdondes's Avatar
rdondes
rdondes is offline
You should be checking all your bolts, fasteners, etc. as part of the pre-ride TCLOCSs check every time you ride. Anyone whose exhaust falls off because of loose bolts has only their own negligence to blame.
See the MSF's TCLOCs checklist at: http://www.msf-usa.org/downloads/T-C...nChecklist.pdf
Old 06-12-2009, 10:46 PM
2007z71's Avatar
2007z71
2007z71 is offline
Its almost like I have heard this before?
Old 06-12-2009, 11:17 PM
BlackSpecial's Avatar
BlackSpecial
BlackSpecial is offline
A gal I work with had both her stock mufflers fall off. She has an '07 Dyna with about 10k on it. Bone stock.
Bet she checks them bolts on a regular basis now.
BTW, I wonder how many riders actually do that complete checklist every time they ride. I know I don't.....
Old 06-12-2009, 11:48 PM
rdondes's Avatar
rdondes
rdondes is offline
I check the air in my tires, all fluids, all electrics and every bolt and fastener I can get to from the front tire to the rear license plate every time I take my bike out of the garage. It takes me 15 minutes. To have one's footpegs, exhaust pipes, horn, seat, license plate, air cleaner, battery box cover, battery cables, rear belt pulley, headlight, etc. etc. fall off because of neglecting the TCLOCs check is sheer negligence. Same for neglecting replacement of worn tires and checking the operation of the brakes. And because riding a motorcycle is inherently a thousand times more dangerous than driving a car, neglecting the pre-ride check is not smart either. Riding your bike like you stole it is fine - I do it all the time. But only after I've checked the bike out.
Quick Reply: slip on's almost slipped off
