Recalls
http://www.lemonauto.com/complaints/...FQEoGgodVGph1w
or try
http://www.allworldauto.com/recalls/...calls_7-1.html
and
http://www.ehow.com/how_2386526_hand...n-recalls.html
DECEMBER 2008 -- Harley-Davidson is recalling 3,285 MY 2009 FXD, FXDF, FXDC, FXDL, and FXDB motorcycles. The jiffy stand spring anchor may have been built with a defective weld that may allow the jiffy stand assembly to not retract as intended. This condition could lead to a crash which could cause injury or death to the rider. Dealers will remove the original jiffy stand spring anchor and replace it with a new spring anchor free of charge. The recall is expected to begin during January 2009. Owners may contact Harley-Davidson at 1-414-342-4680. 08V-659
NOVEMBER 2008 -- Harley-Davidson is recalling 349 MY 2009 FXDB, FXDC, FXDF, and FXDL motorcycles. These motorcycles have a fuel tank vent tube assembly, Part No. 27389-04A, which may have been produced with a questionable ultrasonic weld on the anti-slosh valve. If the valve separates and the bike is tipped over, it may leak fuel. Fuel leakage in the presence of an ignition source could result in a fire. Dealers will inspect the fuel vent tube assembly and, if necessary, replace it. The recall is expected to begin during December 2008. Owners may contact Harley-Davidson at 1-414-343-4056. 08V-625
If you purchased one of the affected models, you should have received a recall notice from HD. Take the bike in and they'll fix the issue.
I received a recall notice for each issue, and had it taken care of.
I purchased mine in early Aug. 2009, right after the '09's came out.
