won't start?
Old Aug 13, 2009 | 06:03 PM
JoeGrapes's Avatar
JoeGrapes
Default won't start?
ok, this has just started happing the past couple of weeks. When the bike is cold and I hit the start button, nothing happens. It's like the starter button is not making contact. All the lights are bright and I hear the slight buzzing sound of the fuel pump. Then after a few minutes, it starts. I've checked the wiring and all looks fine. No obvious sign of damage. Is there something aside from a broken wire or defective starter switch that can cause this? I have the Harley keyless start system.
Old Aug 13, 2009 | 07:56 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Seems quite prevalent here, did you check the battery connections? Where the cables bolt into the battery? Alot of the new bikes seem to have this problem.
Old Aug 14, 2009 | 04:34 PM
JoeGrapes's Avatar
JoeGrapes
It just dosen't act like a bad connection. This morning I went out and did nothing but push the start button and nothing happened. I waited a few minutes and tried again and it started. I didn't move anything. After work I went out and put both switches to the on posistion and tried the start button, nothing, but I noticed that the turn signals were flashing so I waited until they stopped and bingo, it started. I'm now thinking I might have a weak battery in the key fob. It's been a year since I replaced it. I'll get a new battery and let you know.
Old Aug 14, 2009 | 04:41 PM
formike56's Avatar
formike56
fob battery is bad....
Old Aug 14, 2009 | 05:31 PM
JoeGrapes's Avatar
JoeGrapes
That was it, weak FOB battery. Thanks all.
Old Aug 14, 2009 | 05:45 PM
Steve Zodiac's Avatar
Steve Zodiac
I've had that and it puzzled me for a while. I wish all the faults were that easy to fix.
Old Aug 14, 2009 | 06:08 PM
OGC's Avatar
OGC
4th Gear
I encountered a similar problem and the cause was the ECM not the battery, bike was still under warranty, replaced same no issues since..O7 FXD
Old Aug 14, 2009 | 06:10 PM
stevengb's Avatar
stevengb
I hate key fobs.......
Old Aug 14, 2009 | 06:12 PM
minutemaidman's Avatar
minutemaidman
Happened to me too. Battery was OK in the fod but the connectors were dirty. Cleaned them up and no probs since.
anglerman52
General Topics/Tech Tips
Jan 30, 2016 04:48 PM
1960lespaul
EVO
41
May 22, 2014 11:27 PM
williamhall
Jan 25, 2013 10:11 AM
Sunstone
Sep 4, 2011 02:28 PM
masterblaster
Jan 14, 2008 11:28 AM
