timing cover install
Old Jun 11, 2006 | 10:58 AM
Street Rob's Avatar
Street Rob
Default timing cover install
when putting a new timing cover on a bob, do you need a different gasket than the stock one like you do when you put on a different derby cover. if so, soes anyone have the part number for the gasket i would need?
thanks
Old Jun 11, 2006 | 11:18 AM
jmbear328's Avatar
jmbear328
Default RE: timing cover install
I believe that it does take a different gasket. If you go to the H-D website and brouse through the parts section and find the cover that you have,... it will also list the needed gasket under the item.
John
Old Jun 11, 2006 | 11:37 AM
Street Rob's Avatar
Street Rob
thanks, its not a harley cover though...but im sure the gasket would be the same...i will check it out.
Old Jun 11, 2006 | 11:45 AM
mcurry5's Avatar
mcurry5
are you talking about the little round cover or the whole thing??? If its the little round cover there is no gasket there. if your bike is fairly new you should be able to reuse the same gasket for the actual timing cover. Just inspect it and make sure it isnt torn or anything like that.
Old Jun 11, 2006 | 12:24 PM
Street Rob's Avatar
Street Rob
thanx mcurry...it is just the little timing cover...i was thinking there was a gasket under there...wont worry about it if there isnt.
Old Jun 11, 2006 | 12:40 PM
jackyl's Avatar
jackyl
if it s a 06 u dont need a gasket for the cover.my cam case cover has no hole threw it ,to the timing cover,so its more for just decorative then anything on the new dynas.iam not for sure what model you have.but if it dont have a hole threw your cam case then you dont need a gasket.if it has a hole threw the cam case then you do.
Old Jun 11, 2006 | 12:41 PM
mcurry5's Avatar
mcurry5
yep, simple as taking it off and adding the new one. should take 5 min
Joe-Cool
Jul 31, 2014 09:47 PM
swingdj
Apr 29, 2013 07:31 AM
skdvr
Mar 1, 2011 09:51 AM
OneBlackFly
May 26, 2007 09:02 AM
dawg
Oct 26, 2006 12:29 AM
