wtf
Old Sep 10, 2009 | 12:52 AM
lhcstreetbob's Avatar
lhcstreetbob
Default wtf
i had my lower fork sliders powdercoated and when i was putting the dust cap on with the pvc pipe that everybody uses. the dampner came out of the tube and all the bushings and o rings came apart!!! i dont know if i didnt have the 12mm bolt in tight enough or what? can i just put it all back together or did i break something in there?
Old Sep 10, 2009 | 09:26 AM
07bobber's Avatar
07bobber
refer to repair manual....
Old Sep 10, 2009 | 10:32 AM
SC-Longhair's Avatar
SC-Longhair
Can I ask how that all came apart?
When I swapped lowers, I had the forks assembled and used the pvc method. Nothing was loose.
Is it possible you tried to re-assemble prematurely?
Are you just trying to put the dust seal in without installing the tube?
Old Sep 10, 2009 | 10:45 AM
JRK5892's Avatar
JRK5892
all the bushings? there should be a damper, spring, washer, and spacers... on your fork seals did you put on the o-ring clip, sounds like everythign shot out the top... if so then yes your screw was not in tight enough
Old Sep 10, 2009 | 12:12 PM
lhcstreetbob
i have the manual. it doesnt really cover this i dont think i had everything together including the seals with clip but i didnt tourqe the 12mm nut down just hand tight i guess and when i was hitting it( maybe to hard ) the damper and the spring and washers fell into the slider. according to manual i think i should be able to just put everything back into the tubes right? i was just worried that i may have broke something and that it wasnt suppposd to come apart like that.
Old Sep 10, 2009 | 12:35 PM
SC-Longhair
I agree with Lh....the manual, in reference to fork diassembly is useless as far as procedure goes. The most useful thing in it is the diagram...
Old Sep 10, 2009 | 03:13 PM
lhcstreetbob
i took it the dealer i guess i broke a gromet that is welded in so i need a whole new tube ... oops
Old Sep 10, 2009 | 03:24 PM
maddghost's Avatar
maddghost
Crap man sorry to hear it.
Old Sep 10, 2009 | 03:41 PM
lhcstreetbob
its all good im learning as i go... i would just like to get all back together before arizona riding season.
Old Sep 10, 2009 | 04:38 PM
SC-Longhair
Lh...I have a set of my oem lowers. I'd offer them up to you if they'd work for you. Just pay the shipping. Save you the cost of what the dealer will charge.
