handling issues
Old Oct 5, 2009 | 11:46 AM
  #51
grbrown's Avatar
grbrown
Thumbs up
Originally Posted by rounder
FWIW when I switched from my mini apes to the drag bars, I had an ache in my mid back for the first couple of rides. It no longer occurs so it is possible that the ache will go away once your shoulder is used to the position.
Also being much happier with the bike and more comfortable, you will find you relax more and these sort of tensions may just disappear. Great to hear we have helped you out!
Old Oct 6, 2009 | 05:27 PM
  #52
Lennyone's Avatar
Lennyone
Turning a motorcycle at speed is not easy, what limit my speed is the grip of my tires. When my front tire start to slip means back off. The weight of the bike has a lot to do with it. I would suggest buy a Buell if you want to out turn the other bikes.
Practice, practice, practice is the one thing that helps.
Simple tips in turning
Step 1
Remember that in order to turn, your motorcycle must lean. Push on the left hand grip and lean to the left to turn left, and push on the right hand grip and lean right to go right.
Step 2
Roll on the throttle through the turn, keeping a steady speed or accelerating gently. Avoid slowing down in the midst of a turn.
Step 3
Keep in mind that during routine turns, you and your motorcycle must lean at the same angle. During slow, sharp turns, lean the motorcycle only and keep your body straight.
Old Oct 8, 2009 | 06:00 PM
  #53
June Bug's Avatar
June Bug
Originally Posted by Lennyone
..... I would suggest buy a Buell if you want to out turn the other bikes...
NO NO NO, no Buell! (Sorry buell riders, no offense intended). Seriously though, I do not want to out turn anyone - I just want to be comfortable on, and be able to handle MY bike
..... Practice, practice, practice is the one thing that helps..
Yes, this I definitely agree on. Now that I have more comfort and have some of the confidence back that I had before I made some of the changes way back when, I can practice on overcoming some of my anxiety about wondering what's around those blind curves. I did so much better this past weekend, and that is the only thing left to conquer, I think.
Hey thanks everyone here for all your input. It's the great thing about this forum.
pyuchem
Nov 6, 2020 12:21 PM
Lwilliams1950
Nov 25, 2012 06:30 AM
chrskrngl
Jul 3, 2011 12:26 AM
dynacruiser
Jan 30, 2008 05:48 PM
jeb_cfl
Nov 2, 2007 09:39 PM
