2010 Dyna Question
I have a 2010 wide glide and I'm getting ready to install my V&H big radious pipes. Does anyone have the torque numbers for the 4 header bolts? Sorry my service manual is on order i just haven't recieved it yet.
Greg
According to the 07 Manual:
Tighten flange nuts (35), at front cylinder studs as follows:
a. Install lower nut and tighten finger tight.
b. Install upper nut and tighten to 9-18 in-lbs (1-2 Nm).
c. Tighten lower nut to 60-80 in-lbs (6.8-9.0 Nm).
d. Tighten upper nut to 60-80 in-lbs (6.8-9.0 Nm).
8. Tighten flange nuts at rear cylinder studs as follows:
a. Install upper nut and tighten finger tight.
b. Install lower nut and tighten to 9-18 in-lbs (1-2 Nm).
c. Tighten upper nut to 60-80 in-lbs (6.8-9.0 Nm).
d. Tighten lower nut to 60-80 in-lbs (6.8-9.0 Nm).
