Lowrider exhaust pipes / install
Old Apr 27, 2005 | 11:08 PM
tl vette's Avatar
tl vette
Default Lowrider exhaust pipes / install
I have a buddy that is putting a stock set of pipes on his lowrider. the pipes came as pipes only and he went out and bought the flanges.
now we know thw flanges go over the pipe but there must be a compression type seal to go between the flange and the flared out part. Is this correct?
and does anyone know the torque setting for the flanges when he installs?
Thanks
TL
[IMG]local://upfiles/1714/C594A818477C4EA3AAF7BC4CD212107D.jpg[/IMG]
Old Apr 28, 2005 | 02:11 AM
mikeisglidn's Avatar
mikeisglidn
Default RE: Lowrider exhaust pipes / install
if its like every harley exhaust ive seen it has a snap ring, torque, beats me, tignt!
Old Apr 30, 2005 | 12:41 PM
DGlide04's Avatar
DGlide04
I just finished installing a set of V&H pipes on my '04 FXD. tl vette is right, the only thing that goes on the pipe in between the header and the flange is the steel snap ring that will tighten down when the flange bolts are tightend.
As far as the nuts on the flange, HD service manual for the Dyna FX models shows between 60-80 in. lbs. as the correct torque. There is a pattern for tightening the nuts as follows:
Tighten the at front cylinder as follows:
1- Insall lower front nut finger tight.
2- Install upper nuth and tighten to 9-18 in.lbs. (1-2 Nm)
3- Tighten lower nut to 60-80 in. lbs.
4- Tighten upper nut to 60-80 in. lbs.
Tighten nuts on rear cylinder head studs as follows:
5- Install upper nut and tighten finger tight.
6- Install lower nut and tighten to 9-19 in. lbs.
7- Tighten upper nut to 60-80 in. lbs.
8- tighten the lower nut to 60-80 in. lbs.
Hope this helps out your buddy.
ORIGINAL: tl vette
Thanks
TL
Old May 2, 2005 | 11:15 PM
tl vette's Avatar
tl vette
thanks, it does. we got the snap ring and just needed the torque setting.
Thanks again
TL
Bocefus
Jul 14, 2014 09:40 PM
Tat2u
Mar 30, 2014 11:49 PM
GymChamp
Nov 21, 2009 02:52 AM
HDRoach
Exhaust System Topics
Apr 18, 2008 12:09 PM
bobby5
Mar 11, 2007 12:34 PM
