help pls
Old Nov 3, 2009 | 01:55 PM
NOZEM's Avatar
NOZEM
Default help pls
My "nut" to attach my solo seat to (insided the fender) broke. I cannot get in there to replace it because the bike sits too low on the tire. Right now I just have a hole in the fender. Any similar experiences? Any ideas to fix? Thanks!!!
Old Nov 3, 2009 | 02:08 PM
YellowHawk's Avatar
YellowHawk
If you get a new one, slip a long tie wrap through the nut part and stick the tie wrap up through the hole in the fender. You should be able to do this without having to get your hand up under the fender. The head on the tie wrap will keep the nut from slipping off the end. Then grab the tie wrap up on top of the fender and pull the nut up into place. Then you can hold it there to put the c-clip on. You could also use a piece of safety wire or something else.
Old Nov 3, 2009 | 02:20 PM
08fxdf43202's Avatar
08fxdf43202
The only other way would be to get a lift/jack, raise the rear, pull the shocks & drop the swing arm. If you do... be sure to check the tightness of your rear motor mount.
JRK5892's Avatar
JRK5892
zip tie method works... JP cylcles carries the seat nut for like 10 bucks...
Old Nov 3, 2009 | 03:16 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Hi Arie,
Here is an image of the fender seat nut assambly kit p/n 59768-97 (see attachement) as used on my FXD2003.
I guess the p/n goes for your bike as well. Price at ChicagoHarley.com US$ 2.00
Zip tie or fishing line attacheted to a match which holds the nut will do the trick.
FXD2003Rider
Old Nov 3, 2009 | 03:36 PM
2007fxdc's Avatar
2007fxdc
Tie wrap method is the proven way. If you need clearance for that, lift the bike up to drop the rear wheel a little.
Old Nov 3, 2009 | 04:14 PM
NOZEM's Avatar
NOZEM
Thanks guys, I will try tonight.
Old Nov 3, 2009 | 07:04 PM
bigdaddy33's Avatar
bigdaddy33
Used the zip tie trick a few years ago and it works great. Glad it was posted. I'd forgotten about it.
Old Nov 3, 2009 | 07:09 PM
Way2Fast's Avatar
Way2Fast
I dropped a length of heavy string through the top of the hole so it dropped down by the wheel then put the nut on the string, tied a big not in the string and pulled the nut up and slipped the plastic washer/clip on... then pushed the string down through the hole .. WAAA lAAA done.
Old Nov 3, 2009 | 07:46 PM
maddghost's Avatar
maddghost
I used duct tape on the end of a paint stir stick,but next time (if there is a next time) I'll go the zip tie way.....sounds really easy and less stuff to get together!
