98 dyna ignition wire.?
Old Jul 9, 2006 | 10:39 PM
barhpr's Avatar
barhpr
Default 98 dyna ignition wire.?
puttin a alarm on my stepdads 98 dyna.. is there a easier place to tap on the ignition wire besides pulling the enitre ignition off?
Old Jul 10, 2006 | 08:31 AM
klagair's Avatar
klagair
Default RE: 98 dyna ignition wire.?
Going on a bit of memory here.
Take your power directly from the main fuse box.
The incomming from the main fuse is the red, other wires do go back and feed the fuse box from the ignition, it is not good practice to use these as you may pick one that is only activated when the ignition is on. You need to take it from the other side of the fuse (15 Amp) and the wire colour should be a (brown / grey) with a red as the main supply.
Hope this helps.
Cheers
Jward11
Ironhead
Yesterday 05:35 PM
2carter3
EVO
28
Aug 15, 2018 05:56 PM
jacknthebox
Apr 22, 2013 09:03 AM
ncottrell2009
Ironhead
Oct 16, 2012 06:29 PM
jacknthebox
Mar 16, 2012 06:04 PM
