Cams
Old Jan 4, 2010 | 06:42 PM
wideglidebob's Avatar
wideglidebob
Thumbs up Cams
I khave a 05 dyna and was going with gear drive, but dealer talked me out of it and said they have a new part 25284-08 that replaces the plastic tensioner with a better hydraulic system that the 06 came with it also comes with the better oil pump, and i thought as long as they are in there i should change the cams so i cannot find the wood bros i keep hearing about does anyone know there web page need to know if they make a set for the hydralic system or maybe just go to the gear drive but i hear they are noisy ect what do ya think
Old Jan 4, 2010 | 06:51 PM
glideridemike's Avatar
glideridemike
Periods man
Old Jan 4, 2010 | 06:52 PM
B767's Avatar
B767
Here is the Wood's website.
http://www.woodcarbs.com/
Old Jan 4, 2010 | 06:54 PM
reded's Avatar
reded
Old Jan 4, 2010 | 07:36 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The dealer maybe talking about the new cam support plate with the hyd cam chain tensioners. I 'm sure most cam makers have cams that will work with this support plate. It's also my understanding that the cams don't ride in bearings just parent material. I could be wrong.
Old Jan 4, 2010 | 07:56 PM
reded's Avatar
reded
You are correct.
Old Jan 5, 2010 | 08:03 AM
rounder's Avatar
rounder
the new cam plate kit is pretty nice, you get an updated oil pump too. Personally, I would run the gear drive cams myself. They are not really all that loud. Cycle-rama's custom grind cams are available to the public now. I would use their cams over any other.
Old Jan 5, 2010 | 08:32 AM
glideridemike
I plan on changin my tensioners if needed.....gotta get out there and crack open the case and see whats up.....27k miles on mine.
Old Jan 5, 2010 | 08:52 AM
Lama's Avatar
Lama
No need to go gear drive.
Buy an Andrews "N-Series" conversion cam in one of their great grinds:
http://www.andrewsproducts.com/PDF_f...versionCam.pdf
Screamin Eagle 25284-08 Hydraulic Tensioner Upgrade Kit
http://cgi.ebay.com/ebaymotors/H-D-H...Q5fAccessories
Screamin Eagle 25285-08 spacer kit
http://cgi.ebay.com/ebaymotors/Screa...Q5fAccessories
Old Jan 5, 2010 | 11:28 AM
paul s's Avatar
paul s
I wouldn't touch gear drives without a trued and welded crank. The chains are more forgiving on tolerances.
