wrong choice for a cam
Old Feb 26, 2010 | 03:22 PM
dyna081's Avatar
dyna081
Default wrong choice for a cam
does anyone like the SE 255 so far im not finding anyone
Old Feb 26, 2010 | 03:31 PM
bigmikaele's Avatar
bigmikaele
When I was getting my engine rebuilt the guy doing the work shy'd me away from them. He said they were good at mid-level RPMs but then they fell away as the RPMs went above 4K. Based on discussion and cost he suggested the Andrew's 31H cams for me, but I know that there are some more radical cams out there that most people go with...
BLUF: the SE 255 cams are ok, might be better then stock, but on average, from what I have read on here, most people would opt for something else.
Old Feb 26, 2010 | 03:39 PM
chad peterson's Avatar
chad peterson
Yup these cams fall off really early for sure...depends on what ya want out of a set of cams, where ya want the power! They're ok for some but not many!
Old Feb 26, 2010 | 03:51 PM
Inspector 12's Avatar
Inspector 12
For my application, the SE 255 cams are perfect. I am riding a Street Glide and don't plan to spin the motor to the moon. I like the idea that the torque comes in early and stays there across the rpm range where I ride the most. To date I haven't spun my bike much over 4500 RPM which is about where the SE 255 noses over.
Old Feb 26, 2010 | 04:09 PM
SC-Longhair's Avatar
SC-Longhair
With a harley, I think it's safe to say that 99.9% of us want power in the low-mid range. I couldn't think of a reason to have a cam that kicks in at 4k rpm. Maybe a drag bike thats leaving the gate at 3-4k rpm.
Although, whats to stop you from adjusting the cam timing a bit to get the powerband closer to where you want it.
Old Feb 26, 2010 | 05:22 PM
paul s's Avatar
paul s
If you want to hear good things about the 255 go ask in the bagger section.
Old Feb 26, 2010 | 05:25 PM
1plumr1's Avatar
1plumr1
They work real well in the wife's tri-glide, but that is a 103.
thedonthere's Avatar
thedonthere
about $250.00 for the adjustable cam gear!!
http://hemrickperformance.com/camgear.aspx
Old Feb 26, 2010 | 06:02 PM
red devil's Avatar
red devil
The 255's are decent cams when used in the correct application. They are good for the heavier bikes and/or someone thats looking for more low end for 2-up riding, or someone who just likes to putt around. If you like riding your bike hard and pushing the rpms up, there not for you.
Old Feb 26, 2010 | 06:51 PM
U-234's Avatar
U-234
On one of the other Harley forums the SE 255 seems to be pretty popular in the 96in. engine with A/C and pipe mods. You can find the cam for less than $200 and it's a straight bolt-in. Cheap added power.
