Shocks
Old Mar 28, 2010 | 05:39 PM
Jessie's Avatar
Jessie
Thumbs up Shocks
OK Guy's can I put 09 12 in lowrider shocks on a 07 FXDC my 07 is 12.6 and the 09,s are 12 so I would like to lower it a lil but dont no if they will fit they are new and for only 59.50 the guy never used them took them off when new ? As usual Thank you for your input !JT
Old Mar 28, 2010 | 07:02 PM
Smitty79's Avatar
Smitty79
They should fit as far as i know. And for only 60 bucks even if they don't you can sell them for more than that.
Old Mar 28, 2010 | 07:18 PM
hell hound's Avatar
hell hound
they should work fine (I think)
Old Mar 28, 2010 | 10:52 PM
archergodwin's Avatar
archergodwin
The only thing I would make sure of is.. I believe... starting in 08, the top shock mount is a stud and not a bolt. I'm not sure if they are the same diameter.
as far as length.... 12" is great on the fxdc... i have 12" Progressive 412HDs on mine.
Old Mar 29, 2010 | 12:26 PM
Jessie's Avatar
Jessie
Default changing shocks
Do I need to have a jack to change shocks ? Can it be done on the side stand ? Thank's Guy's
Old Mar 29, 2010 | 01:27 PM
Lorance66's Avatar
Lorance66
they should fit no problem.....a lift is nice but if you don't have one get a buddy who can lift a bit or push down a bit on the fender for you.....just in case.
Old Mar 29, 2010 | 04:47 PM
grbrown's Avatar
grbrown
Wink
I suggest you use a jack under the frame to lift it a little, so the shocks are full length before you remove them.
peterllo
May 11, 2019 01:29 PM
s13steve
Feb 4, 2019 10:13 PM
bufbills
Jun 21, 2015 11:56 PM
bighaeb
Oct 20, 2009 06:00 PM
QuentiN
Sep 5, 2007 08:38 AM
