Petcock???
Old Apr 3, 2010 | 11:11 PM
stahrman02's Avatar
stahrman02
2nd Gear
Default Petcock???
Does anyone know the proper way to use the petcock? Are you supposed to turn the gas off everytime you park for awhile or only when working on your bike?
Old Apr 3, 2010 | 11:25 PM
Clipper's Avatar
Clipper
The only time mine was every turned off was during Winter storage. Never had a single problem.
I believe relatively new models have some sort of float valve, or vacuum which makes it safe to leave the gas on. I'm sure someone can explain it better than me.
Old Apr 3, 2010 | 11:40 PM
ghostrider69's Avatar
ghostrider69
On my old 91 Springer I just made it a habit to close it every time I parked. It doesn't take much for just a small piece of trash to hold the float needle open which could cause gas to leak through the carb. I had a carb on it at one time that just the leaning of the bike on the kick stand would cause the float to let gas continually flow. If I tried to adjust it it would have to low of a float level. Needless to say it was very touchy. The newer fuel injected bikes don't use petcocks.
Old Apr 4, 2010 | 12:08 AM
j1mmy's Avatar
j1mmy
if you leave the fuel valve on when the bike is parked, it can/will flood from time to time, the problem with it flooding besides the mess, is the gas on the floor will evaporate before you see it, but it will also run into the cylinders then wash down and dilute the oil,causing the engine to run dry..it causes cylinder and bearing wear/failure.. no warrenty will cover it if they figure out what caused it (smell fuel in the oil).. i have had to rebuild my shovel and literley dozens of rice bikes at work from the valve being left on all the time..the owners manuel says to turn off the valve when the engine isnt running..
Old Apr 4, 2010 | 01:09 AM
BLKBAGGER's Avatar
BLKBAGGER
Newer Harleys used a vacuum operated petcock. If it is working properly it's fine to leave it on all the time. No vacuum from the running engine= no fuel.
Old Apr 4, 2010 | 05:20 AM
Derv's Avatar
Derv
What 'e said. If it's a later bike with the vacuum op petcock leave it on it'll be fine, there's no way fuel can flow unless the motor is running.
Derv
George Tirebiter
Jul 8, 2016 12:32 PM
gregjo1948
EVO
Sep 16, 2014 06:04 PM
SportsterSnow
Apr 10, 2013 04:05 PM
electra glide
Exhaust System Topics
Oct 18, 2009 10:06 AM
imboden
Classic
May 14, 2006 04:58 PM
