Need some help
Old Apr 5, 2010 | 02:05 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by Lorance66
I just want to say that FXD2003Rider has some of the best, most informative and helpful answers every time I see him post. Usually with a link too! Great to have guys like you on here.
Thanks for the compliment, Brad....I really appreciate your positive feedback!
I'm just trying to make the best out of it......
FXD2003Rider
Old Apr 5, 2010 | 04:18 PM
streetbobkid's Avatar
streetbobkid
im not sure if it is the switch, with the run switch turned off it all operates correctly, when i switch it to run they come on and stay on,
the same thing happens even after taking it apart and cycling the switch with my finger. im not sure what it is yet, could it be something to do with having no front turn signals, all of the handlebar switches operate correctly, could it be in the run brake turn signal module, i have no wires running under my fender, they are behind the strut covers
if i happen to find a fix i will definitely update, i just got a set of rear signals off of an 09 to install and realized they have three wires, may take a bit to get them wired in, but i am also going to check the ignition switch thanks for the advice
Old Apr 10, 2010 | 06:51 PM
streetbobkid
after tearing it all apart i decided to hook up the stock tail light bulb without the run, brake, turn signal module in the middle and it works correctly,
doesn't make any sense to me that it works without it, even though it functioned correctly without being switched to run, can anyone give me the part number for the biketronics one thanks
Old Apr 10, 2010 | 09:29 PM
Two Feathers's Avatar
Two Feathers
Not to hijack, but FXD is Very infromative I have many posts saved in favorites from him, to the op, glad you found the problem, I will remember this fix if I ever have issues similar to yours
xlh883.87
Feb 1, 2019 02:42 PM
ndnbennyb
May 9, 2013 12:19 PM
KW-HD Rider
Wheels/Tires
11
Aug 12, 2010 09:32 PM
bw1234
Apr 15, 2008 08:37 PM
trapperdog
Jan 15, 2008 05:52 PM
