My Speedometer took a dump!
Old May 13, 2010 | 09:41 AM
RandyDowdy's Avatar
RandyDowdy
You can also look real close at the needle in the speedo itself. Sometimes the black inside ring can swell/distort, and the needle will hang up. Good luck, RD.
Old May 13, 2010 | 09:42 AM
SURFOR Chop's Avatar
SURFOR Chop
If you can find the P/N, you might consider ordering through Zanotti or Chicago H-D for a 15-25% discount ....
If it's the speedo itself will cost around $400+ ... might be an opportunity to switch to one of the speedo/tach units or something ....
I'd check the sensor, wires, fuse, etc. ... also, could be a bug or glitch in the ECM ... might try to see if there are any 'codes' (look in the service manual for interpretation) or if the dealer can check it for you ....
'02 Screamin' Eagle Wide Glide ... huh? ... Sweet bike--sorry to hear it's actin' up on ya ....
R/
'Chop
Old May 13, 2010 | 01:19 PM
victoriouz's Avatar
victoriouz
Okay, so I need to check the speedo, wires beneath it, fuse, battery, sensor and connetions for corrosion... anything else? that sounds like the whole system to me. :-/
well, I better get on it. Thanks all, for your advice.
Old May 14, 2010 | 06:35 AM
RandyDowdy's Avatar
RandyDowdy
I bought one brand new , still in HD box, 0 miles, off of fleabay for $100.
wattey1947
Jun 13, 2018 01:12 PM
dstlcox
Apr 2, 2012 07:13 PM
dcipilot
Jun 16, 2010 02:38 PM
menderle
Aug 26, 2005 10:28 AM
Sincecrazy
Jul 27, 2005 10:51 AM
