My Speedometer took a dump!
Old May 12, 2010 | 10:52 PM
victoriouz's Avatar
victoriouz
Default My Speedometer took a dump!
Dude!
My speedo is going crazy. Starts out fine when the engine is cool but 10-20 min into a ride it starts flipping out and eventually goes to zero!
I talked to Harley, dudes said its usually the wires that go to the sending unit... yeah, I checked them... they're on there... I can't tell if they're good or bad and don't want to fork out the cash for the dealer to do it if its just the sending unit... Anybody have any thoughts where the issue may be? Do I have a bad gauge, Sending unit, wires, fuse, or is it the gear in the Tranny? Oh crap... this sounds expensive.
Old May 12, 2010 | 11:46 PM
SC-Longhair's Avatar
SC-Longhair
Pull the connector and check the terminals for any corrosion. If present, clean it then put some dielectric grease on the terminals and reconnect.
Old May 12, 2010 | 11:52 PM
RandyDowdy's Avatar
RandyDowdy
An allen bolt holds the sensor into the case. Not too easy to get to, but doable. Pull it out, clean it well, and put it back. That fixes many problems right away. Good luck!
Old May 13, 2010 | 12:02 AM
forever 2 wheels's Avatar
forever 2 wheels
Smile
Had same issue on 2003 Ultra Classic. Cleaned metal off sensor re-installed sensor. Worked aboout 100 miles then more problems. Bought new sensor $65.00. Bike had close to 35K miles on speedo when it failed..Very easy part to locate. Remove seat to locate wires and unplug. Hope this helps.
Old May 13, 2010 | 12:13 AM
victoriouz's Avatar
victoriouz
i dont see an allen bolt.
I got an 02 Wide glide. All I see is the sensor sticking out from the top of the tranny. It screws out easily enough... but no allen bolt. Am I looking in the wrong place?
Old May 13, 2010 | 12:27 AM
forever 2 wheels
Not sure, just pulled up JP Cycles parts picture of sensor. Appears to be same as my 2003 sensor with allen head bolt hold down. Same price also.
Old May 13, 2010 | 12:38 AM
forever 2 wheels
Smile
Thinking back, sensor was located on right side of bike top of tranny. Couple years since I sold bike. The only other problem I had was a loose battery connection causing speedo and tach to act crazy, good luck. Do a search and you may see something that helps. Someone must have a picture of location and part you are looking to replace..
Old May 13, 2010 | 01:22 AM
victoriouz's Avatar
victoriouz
Battery! ah... haven't checked that yet... Thanks. I'll get on that at sunbreak.
Old May 13, 2010 | 02:14 AM
Lincoln33's Avatar
Lincoln33
It really sounds like the speed sensor to me. My 01 RK had all the same symptoms and replacing the sensor solved the problem.
Old May 13, 2010 | 08:54 AM
bikerlaw's Avatar
bikerlaw
My low Rider started the same nonsense. I went to the dealer, bought a new sensor and installed it. Nothing. The experts told me to check the wires under the tank as they often get pinched or wear through as well. Thats the route I would recommend first since its free, vs the 60 bucks for the sensor. Most likely its one or the other. Last possibility is the speedo itself took a dump. Now thats expensive. i hope for both of us it ain't that. You can always pull the speedo and take it to a dealer, they told me they could check it if needed.
