speedometer
Old Apr 2, 2012 | 06:26 PM
dstlcox's Avatar
dstlcox
Default speedometer
was riding this weekend and my speedometer started bouncing then finally went to zero and odometer quit also ,got to my daughters and looked around for possible short ,bike set for about 3 hours and we headed home it worked fine for about 20 miles then quit again ,my engine light came on ,everything else is working fine is there anything i can check without taking it to the stealer ? oh yea it's a 03 ultra
Old Apr 2, 2012 | 06:43 PM
scotty3's Avatar
scotty3
Speed sensor on top of transmission.
Pull it out and see if covered with metal filings.
If it is clean it and give a whirl but you will probably need a new one.
Old Apr 2, 2012 | 07:13 PM
tommy120's Avatar
tommy120
I had the same problem.. it was a broken wire. I checked the wires for grounds and rang them out with ohm meter. It broke right before it goes under the tank from the sensor side.
wattey1947
Jun 13, 2018 01:12 PM
theCoach
Jun 12, 2018 11:33 AM
dstlcox
Apr 2, 2012 06:31 PM
dcipilot
Jun 16, 2010 02:38 PM
victoriouz
May 14, 2010 06:35 AM
