I have a 07 Dyna Super Custom that I want to install new drag bars on ,but Im not sure how much riser height will work with out changing the cables,,,,,HELP!!!!
I had wild1's with 8 inch rise and didn't have to change any cable....did have to straighten out the top metal part of the brake line...do that very carefully...
when i installed 10" t bars all that was needed were 2" longer throttle cables. width of the bars also comes into play as well. you should be fine at 8" without changing anything.
i have a 05 wideglide and am thinking about going with 12 to 13 in tall want a little taller and a little more back, anyone know of someone who makes gooduns
Maybe the differance between the rise of each bar would be a clue to the new riser height.
I have an 09 night train, with stock 6" risers and drag bars 28"wide that have a 4" pull back. How much of a rise and a pull back can I go without changing any of the cables? Example: 7" rise 6" pull 30.5 wide, will this work?
