Duce Risers
Old May 17, 2010 | 05:08 PM
BlockHead96's Avatar
BlockHead96
Default Duce Risers
Will all years work on the newer Dynas or more recent years only? Any mods need to be done to the Duce Riser to fit the Dyna?? I want my OEM bars back a little more and heard talk of using Duce Risers.
Old May 17, 2010 | 07:59 PM
SC-Longhair's Avatar
SC-Longhair
I don't see why they wouldn't just bolt up to your trees. Only difference is that you may have 1.25" bars...and those risers may be for 1".
BTW, it's Deuce.
Old May 17, 2010 | 08:04 PM
macnab_sf's Avatar
macnab_sf
Il Duce on a riser:
Old May 17, 2010 | 08:07 PM
bord3r's Avatar
bord3r
try it and let us know how it works out... should be fine as long as the bars are the same diameter
Old May 17, 2010 | 08:49 PM
murphdog's Avatar
murphdog
Deuce risers aren't flat on the bottom where they sit on the riser bushing cups. You could cut or grind the nubs off, but why not just get some correct 6" pullbacks that will work without modification?
Old May 17, 2010 | 08:51 PM
fhansen's Avatar
fhansen
The Lowrider pullbacks are nearly as tall and have the flat bottoms.
Old May 18, 2010 | 01:30 AM
BlockHead96
Gotta check J&P Cycles and see if they may have what your talking about
Old May 18, 2010 | 01:32 AM
BlockHead96
That's what I'm already working with, I have a Low Rider, just want a little more height and pull back, the bars are OK, at least for now.
Old May 18, 2010 | 02:10 AM
BlockHead96
This may be the ticket! I believe the stock ones on mine are 4", the extra 2" may be just right.
http://www.latus-harley-davidson.com...r-6-Curved.htm
Old May 18, 2010 | 08:08 AM
fhansen's Avatar
fhansen
I've seen them a lot cheaper than these-J&P Cycles for one. Also, this style riser is made in 1" and 1.25"-the fatter ones might appeal to you more as they're more similar to the Lowrider and Duece risers in that regard.
